<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process"> <process expanded="true" height="446" width="534"> <operator activated="true" class="generate_data" compatibility="5.0.10" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_of_attributes" value="4"/> <parameter key="attributes_lower_bound" value="0.0"/> </operator> <operator activated="true" class="generate_aggregation" compatibility="5.0.10" expanded="true" height="76" name="Generate Aggregation" width="90" x="246" y="30"> <parameter key="attribute_name" value="SumAll"/> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="att4|att3|att2|att1"/> </operator> <operator activated="true" class="loop_attributes" compatibility="5.0.10" expanded="true" height="60" name="Loop Attributes" width="90" x="45" y="165"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="att4|att3|att2|att1"/> <process expanded="true" height="446" width="534"> <operator activated="true" class="branch" compatibility="5.0.10" expanded="true" height="76" name="Branch sum!=0?" width="90" x="179" y="30"> <parameter key="condition_type" value="attribute_value_filter"/> <parameter key="condition_value" value="sum != 0"/> <process expanded="true" height="446" width="242"> <operator activated="true" class="generate_attributes" compatibility="5.0.10" expanded="true" height="76" name="Generate Attributes" width="90" x="45" y="30"> <list key="function_descriptions"> <parameter key="rel_%{loop_attribute}" value="%{loop_attribute}/SumAll"/> </list> </operator> <connect from_port="condition" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> <process expanded="true" height="446" width="242"> <operator activated="true" class="generate_attributes" compatibility="5.0.10" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="45" y="30"> <list key="function_descriptions"> <parameter key="rel_%{loop_attribute}" value="0"/> </list> </operator> <connect from_port="condition" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Branch sum!=0?" to_port="condition"/> <connect from_op="Branch sum!=0?" from_port="input 1" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate Aggregation" to_port="example set input"/> <connect from_op="Generate Aggregation" from_port="example set output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="126"/> <portSpacing port="sink_result 2" spacing="36"/> </process> </operator></process>
