Hi:
When using WEKA learner in RM 4.6, I notice that I may need to define a system property named rapidminer.weka.jar according to this link
http://rapid-i.com/wiki/index.php?title=Integrating_RapidMiner_into_your_application#RapidMiner_as_a_library][url]http://rapid-i.com/wiki/index.php?title=Integrating_RapidMiner_into_your_application#RapidMiner_as_a_library.
This allows RM to know where the weka jar file is.
I am using eclipse to do the development, and I have tried to define this rapidminer.weka.jar as an environment variable in run configuration. But rapidminer still cannot find the weka jar file when doing initialization (RapidMiner.init()).
So how should this system property be defined? Any suggestion is appreciated!
