<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="235" width="279"> <operator activated="true" class="read_csv" compatibility="5.0.8" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30"> <parameter key="file_name" value="file:/C:/Dokumente%20und%20Einstellungen/mraeder/Desktop/Test.csv"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="text:generate_extract" compatibility="5.0.6" expanded="true" height="60" name="Generate Extract" width="90" x="179" y="30"> <parameter key="source_attribute" value="File name"/> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"> <parameter key="File Extension" value=".*\.(.*)"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Generate Extract" to_port="Example Set"/> <connect from_op="Generate Extract" from_port="Example Set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
