Exception: com.rapidminer.repository.RepositoryExceptionMessage: Cannot store data at 'C:\Documents and Settings\nterziev\My Documents\Work\Spock\SeatAVL.ioo': java.io.FileNotFoundException: C:\Documents and Settings\nterziev\My Documents\Work\Spock\SeatAVL.ioo (The system cannot find the path specified)Stack trace: com.rapidminer.repository.local.SimpleIOObjectEntry.storeData(SimpleIOObjectEntry.java:136) com.rapidminer.repository.local.SimpleFolder.createIOObjectEntry(SimpleFolder.java:131) com.rapidminer.repository.RepositoryManager.store(RepositoryManager.java:281) com.rapidminer.gui.tools.dialogs.wizards.dataimport.DataImportWizard$1.run(DataImportWizard.java:82) com.rapidminer.gui.tools.ProgressThread$2.run(ProgressThread.java:165) java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) java.lang.Thread.run(Thread.java:619)CauseException: java.io.FileNotFoundExceptionMessage: C:\Documents and Settings\nterziev\My Documents\Work\Spock\SeatAVL.ioo (The system cannot find the path specified)Stack trace: java.io.FileOutputStream.open(Native Method) java.io.FileOutputStream.<init>(FileOutputStream.java:179) java.io.FileOutputStream.<init>(FileOutputStream.java:131) com.rapidminer.repository.local.SimpleIOObjectEntry.storeData(SimpleIOObjectEntry.java:130) com.rapidminer.repository.local.SimpleFolder.createIOObjectEntry(SimpleFolder.java:131) com.rapidminer.repository.RepositoryManager.store(RepositoryManager.java:281) com.rapidminer.gui.tools.dialogs.wizards.dataimport.DataImportWizard$1.run(DataImportWizard.java:82) com.rapidminer.gui.tools.ProgressThread$2.run(ProgressThread.java:165) java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) java.lang.Thread.run(Thread.java:619)
Try the following things:- try to import a cvs or excel file into a repository at another location, best somewhere in your user directory.
