example sets without attributes
outer_space
When I use rss feed miner, the example sets have attributes that appear in a dropdown box when I load "select attributes" operator. When I use web crawler, it outputs into a table with fields link and page. However, when I try to use "select attributes" there is nothing in the dropdown box, it does not let me select Page when I manually type it in.
How do you access the link and page parts of web crawler example sets? I need to convert the page part to a document so I can convert html to text, how do you do this?
colo
it seems those standard attributes from some operators are not available as meta data during process creation, so you have to check the relevant attribute names (case-sensitive!) before and type them manually. This should work fine with a "Crawl Web" operator and "Select Attributes" (attribute filter type: single, attribute: Page). If both operators are connected properly I don't know a reason why this should not work.
But perhaps you consider to abandon the plan of conversion into document if you read the response to your topic regarding the conversion.
