Please note your can define a logical OR of several conditions with ||
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.0" expanded="true" name="Root"> <parameter key="logverbosity" value="warning"/> <process expanded="true" height="406" width="835"> <operator activated="true" class="retrieve" compatibility="5.0.0" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="../../data/Iris"/> </operator> <operator activated="true" class="k_means" compatibility="5.0.0" expanded="true" height="76" name="KMeans" width="90" x="180" y="30"> <parameter key="k" value="3"/> </operator> <operator activated="true" class="apply_model" compatibility="5.0.0" expanded="true" height="76" name="ClusterModel2ExampleSet" width="90" x="315" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.0.8" expanded="true" height="76" name="Filter Examples" width="90" x="514" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="cluster=cluster_0||cluster=cluster_1"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="KMeans" to_port="example set"/> <connect from_op="KMeans" from_port="cluster model" to_op="ClusterModel2ExampleSet" to_port="model"/> <connect from_op="KMeans" from_port="clustered set" to_op="ClusterModel2ExampleSet" to_port="unlabelled data"/> <connect from_op="ClusterModel2ExampleSet" from_port="labelled data" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/> <connect from_op="Filter Examples" from_port="original" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
