<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="358" width="539"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="30" y="79"/> <operator activated="true" class="loop_examples" expanded="true" height="76" name="Loop Examples" width="90" x="169" y="83"> <process expanded="true" height="376" width="557"> <operator activated="true" class="set_macro" expanded="true" height="76" name="reset runs" width="90" x="38" y="29"> <parameter key="macro" value="run"/> <parameter key="value" value="1"/> </operator> <operator activated="true" class="loop" expanded="true" height="76" name="just loop 10 times" width="90" x="199" y="31"> <parameter key="iterations" value="10"/> <process expanded="true" height="376" width="557"> <operator activated="true" class="select_subprocess" expanded="true" height="76" name="do something or not" width="90" x="47" y="34"> <parameter key="select_which" value="%{run}"/> <process expanded="true" height="376" width="314"> <operator activated="true" class="extract_log_value" expanded="true" height="60" name="Extract Log Value" width="90" x="42" y="30"> <parameter key="attribute_name" value="att1"/> <parameter key="example_index" value="%{example}"/> </operator> <operator activated="true" class="log" expanded="true" height="76" name="Log" width="90" x="181" y="27"> <list key="log"> <parameter key="att1" value="operator.Extract Log Value.value.data_value"/> </list> </operator> <connect from_port="input 1" to_op="Extract Log Value" to_port="example set"/> <connect from_op="Extract Log Value" from_port="example set" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> <process expanded="true" height="376" width="253"> <connect from_port="input 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="set_macro" expanded="true" height="76" name="change run" width="90" x="189" y="32"> <parameter key="macro" value="run"/> <parameter key="value" value="2"/> </operator> <connect from_port="input 1" to_op="do something or not" to_port="input 1"/> <connect from_op="do something or not" from_port="output 1" to_op="change run" to_port="through 1"/> <connect from_op="change run" from_port="through 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="reset runs" to_port="through 1"/> <connect from_op="reset runs" from_port="through 1" to_op="just loop 10 times" to_port="input 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Loop Examples" to_port="example set"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
