<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="414" width="758"> <operator activated="true" class="generate_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="loop_examples" compatibility="5.0.8" expanded="true" height="76" name="Loop Examples" width="90" x="179" y="30"> <parameter key="iteration_macro" value="fila"/> <process expanded="true" height="404" width="299"> <operator activated="true" class="extract_macro" compatibility="5.0.8" expanded="true" height="60" name="Extract Macro (2)" width="90" x="45" y="30"> <parameter key="macro" value="att1"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="att1"/> <parameter key="example_index" value="%{fila}"/> </operator> <operator activated="true" class="loop_attributes" compatibility="5.0.8" expanded="true" height="60" name="Loop Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="att2|att4|att3|att5"/> <parameter key="iteration_macro" value="columna"/> <process expanded="true" height="404" width="433"> <operator activated="true" class="extract_macro" compatibility="5.0.8" expanded="true" height="60" name="Extract Macro (3)" width="90" x="45" y="30"> <parameter key="macro" value="att"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="%{columna}"/> <parameter key="example_index" value="%{fila}"/> </operator> <operator activated="true" class="generate_macro" compatibility="5.0.8" expanded="true" height="76" name="Generate Macro" width="90" x="179" y="30"> <list key="function_descriptions"> <parameter key="resultado" value="if (%{att}>0, %{att1}*%{att}, %{att})"/> </list> </operator> <operator activated="true" class="set_data" compatibility="5.0.8" expanded="true" height="76" name="Set Data" width="90" x="313" y="30"> <parameter key="attribute_name" value="%{columna}"/> <parameter key="example_index" value="%{fila}"/> <parameter key="value" value="%{resultado}"/> </operator> <connect from_port="example set" to_op="Extract Macro (3)" to_port="example set"/> <connect from_op="Extract Macro (3)" from_port="example set" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Set Data" to_port="example set input"/> <connect from_op="Set Data" from_port="example set output" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Extract Macro (2)" from_port="example set" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="414" width="758"> <operator activated="true" class="generate_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="generate_products" compatibility="5.0.8" expanded="true" height="76" name="Generate Products" width="90" x="246" y="30"> <parameter key="first_attribute_name" value="att1"/> <parameter key="second_attribute_name" value="att5|att4|att3|att2"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate Products" to_port="example set input"/> <connect from_op="Generate Products" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Is it correct my way?
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="415" width="840"> <operator activated="true" class="generate_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="multiply" compatibility="5.0.8" expanded="true" height="130" name="Multiply (2)" width="90" x="179" y="120"/> <operator activated="true" class="write_csv" compatibility="5.0.8" expanded="true" height="60" name="Write CSV" width="90" x="313" y="120"> <parameter key="csv_file" value="file"/> <parameter key="quote_nominal_values" value="false"/> </operator> <operator activated="true" class="remember" compatibility="5.0.8" expanded="true" height="60" name="Remember" width="90" x="313" y="30"> <parameter key="name" value="ori"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="recall" compatibility="5.0.8" expanded="true" height="60" name="Recall" width="90" x="447" y="345"> <parameter key="name" value="ori"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="remove_from_store" value="false"/> </operator> <operator activated="true" class="read_csv" compatibility="5.0.8" expanded="true" height="60" name="Read CSV" width="90" x="313" y="300"> <parameter key="file_name" value="file"/> <parameter key="column_separators" value=";"/> </operator> <operator activated="true" class="loop_examples" compatibility="5.0.8" expanded="true" height="76" name="Loop Examples" width="90" x="313" y="210"> <parameter key="iteration_macro" value="fila"/> <process expanded="true" height="404" width="299"> <operator activated="true" class="extract_macro" compatibility="5.0.8" expanded="true" height="60" name="Extract Macro (2)" width="90" x="45" y="30"> <parameter key="macro" value="att1"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="att1"/> <parameter key="example_index" value="%{fila}"/> </operator> <operator activated="true" class="loop_attributes" compatibility="5.0.8" expanded="true" height="60" name="Loop Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="att2|att4|att3|att5"/> <parameter key="iteration_macro" value="columna"/> <process expanded="true" height="404" width="815"> <operator activated="true" class="extract_macro" compatibility="5.0.8" expanded="true" height="60" name="Extract Macro (3)" width="90" x="45" y="30"> <parameter key="macro" value="att"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="%{columna}"/> <parameter key="example_index" value="%{fila}"/> </operator> <operator activated="true" class="generate_macro" compatibility="5.0.8" expanded="true" height="76" name="Generate Macro" width="90" x="179" y="30"> <list key="function_descriptions"> <parameter key="resultado" value="if (%{att}>0, %{att1}*%{att}, %{att})"/> </list> </operator> <operator activated="true" class="set_data" compatibility="5.0.8" expanded="true" height="76" name="Set Data" width="90" x="313" y="30"> <parameter key="attribute_name" value="%{columna}"/> <parameter key="example_index" value="%{fila}"/> <parameter key="value" value="%{resultado}"/> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.0.8" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="45" y="120"> <parameter key="macro_name" value="fila"/> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.0.8" expanded="true" height="76" name="Provide Macro as Log Value (2)" width="90" x="45" y="255"> <parameter key="macro_name" value="columna"/> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.0.8" expanded="true" height="76" name="Provide Macro as Log Value (3)" width="90" x="246" y="255"> <parameter key="macro_name" value="resultado"/> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.0.8" expanded="true" height="76" name="Provide Macro as Log Value (4)" width="90" x="447" y="255"> <parameter key="macro_name" value="att"/> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.0.8" expanded="true" height="76" name="Provide Macro as Log Value (5)" width="90" x="447" y="120"> <parameter key="macro_name" value="att1"/> </operator> <operator activated="true" class="log" compatibility="5.0.8" expanded="true" height="76" name="Log" width="90" x="648" y="120"> <list key="log"> <parameter key="Col" value="operator.Provide Macro as Log Value.value.macro_value"/> <parameter key="Fil" value="operator.Provide Macro as Log Value (2).value.macro_value"/> <parameter key="Res" value="operator.Provide Macro as Log Value (3).value.macro_value"/> <parameter key="att" value="operator.Provide Macro as Log Value (4).value.macro_value"/> <parameter key="att1" value="operator.Provide Macro as Log Value (5).value.macro_value"/> </list> </operator> <connect from_port="example set" to_op="Extract Macro (3)" to_port="example set"/> <connect from_op="Extract Macro (3)" from_port="example set" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Set Data" to_port="example set input"/> <connect from_op="Set Data" from_port="example set output" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Provide Macro as Log Value (2)" to_port="through 1"/> <connect from_op="Provide Macro as Log Value (2)" from_port="through 1" to_op="Provide Macro as Log Value (3)" to_port="through 1"/> <connect from_op="Provide Macro as Log Value (3)" from_port="through 1" to_op="Provide Macro as Log Value (4)" to_port="through 1"/> <connect from_op="Provide Macro as Log Value (4)" from_port="through 1" to_op="Provide Macro as Log Value (5)" to_port="through 1"/> <connect from_op="Provide Macro as Log Value (5)" from_port="through 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Extract Macro (2)" from_port="example set" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Multiply (2)" to_port="input"/> <connect from_op="Multiply (2)" from_port="output 1" to_op="Remember" to_port="store"/> <connect from_op="Multiply (2)" from_port="output 2" to_op="Write CSV" to_port="input"/> <connect from_op="Multiply (2)" from_port="output 3" to_port="result 4"/> <connect from_op="Multiply (2)" from_port="output 4" to_op="Loop Examples" to_port="example set"/> <connect from_op="Recall" from_port="result" to_port="result 2"/> <connect from_op="Read CSV" from_port="output" to_port="result 3"/> <connect from_op="Loop Examples" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> <portSpacing port="sink_result 5" spacing="0"/> </process> </operator></process>
