Problem with Parameter Optimization
christian1983
Hi everybody,
in order to improve the performance of a neural network, i´m trying to determine the best network parameter with the optimization operator.
But i get always an error: Process Failed Cannot reset network to a smaller learning rate.
Here is my process:
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process">
<process expanded="true" height="377" width="622">
<operator activated="true" class="retrieve" compatibility="5.0.8" expanded="true" height="60" name="Retrieve" width="90" x="52" y="138">
<parameter key="repository_entry" value="//MyRepository/Data/DM_InputData_C15_Umformgrad"/>
<operator activated="true" class="nominal_to_numerical" compatibility="5.0.8" expanded="true" height="94" name="Nominal to Numerical" width="90" x="179" y="120"/>
<operator activated="true" class="optimize_parameters_grid" compatibility="5.0.8" expanded="true" height="94" name="Optimize Parameters (Grid)" width="90" x="380" y="75">
<list key="parameters">
<parameter key="Neural Net.learning_rate" value="[4.9E-324;20;10;quadratic]"/>
<parameter key="Neural Net.momentum" value="[0.0;10;10;quadratic]"/>
</list>
<process expanded="true" height="395" width="640">
<operator activated="true" class="x_validation" compatibility="5.0.8" expanded="true" height="112" name="Validation" width="90" x="105" y="44">
<process expanded="true" height="395" width="295">
<operator activated="true" class="neural_net" compatibility="5.0.8" expanded="true" height="76" name="Neural Net" width="90" x="53" y="31">
<list key="hidden_layers"/>
<parameter key="learning_rate" value="1.7999999999999998"/>
<parameter key="momentum" value="0.0"/>
<connect from_port="training" to_op="Neural Net" to_port="training set"/>
<connect from_op="Neural Net" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model" width="90" x="23" y="62">
<operator activated="true" class="performance" compatibility="5.0.8" expanded="true" height="76" name="Performance" width="90" x="165" y="116"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_port="input 1" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="averagable 1" to_port="performance"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<connect from_op="Retrieve" from_port="output" to_op="Nominal to Numerical" to_port="example set input"/>
<connect from_op="Nominal to Numerical" from_port="example set output" to_op="Optimize Parameters (Grid)" to_port="input 1"/>
<connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 2"/>
<connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_port="result 1"/>
</process>
</process>
What am I doing wrong?
I hope someone could help me.
Thank you.
land
It seems to me the net cannot be set to a smaller learning rate
During fitting the neural net, the initial learning rate will be decreased with every iteration. Now the implementation seems to avoid setting it to a too small rate. I would suggest to use a higher initial rate? Doesn't this solve the problem.
By the way: It seems to me, you have asked the question already somewhere else. And as you might understand, we are not happy to repeat ourselves...
Greetings,
Sebastian
david
I had the same problem with a dataset and for me it turned out to be a zero-divide prioblem. I have odds in my dataset and when i calculate percentages for them by doing 1/odds and the odds turned out to be a zero i got this error while trying to do a parameter optimization. Just removing the zero-odds from the dataset solved my problem. These showed up as∞ in my example dataset.
