I do the following:
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process">
<process expanded="true" height="521" width="681">
<operator activated="true" class="read_aml" compatibility="5.0.8" expanded="true" height="60" name="Read AML" width="90" x="45" y="30">
<parameter key="attributes" value="C:\Users\eichenbe\Documents\Backup\Laptop\LiveCopy\Software\RM5_tja1055\SigmaTable_Real.aml"/>
<operator activated="true" class="loop" compatibility="5.0.8" expanded="true" height="94" name="Loop" width="90" x="179" y="30">
<parameter key="iterations" value="2"/>
<process expanded="true" height="771" width="867">
<operator activated="true" class="decision_stump" compatibility="5.0.8" expanded="true" height="76" name="Decision Stump" width="90" x="45" y="30">
<parameter key="criterion" value="accuracy"/>
<operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model (2)" width="90" x="179" y="30">
<operator activated="true" class="multiply" compatibility="5.0.8" expanded="true" height="94" name="Multiply" width="90" x="112" y="255"/>
<operator activated="true" class="filter_examples" compatibility="5.0.8" expanded="true" height="76" name="Filter Examples" width="90" x="246" y="255">
<parameter key="condition_class" value="wrong_predictions"/>
<operator activated="true" class="filter_examples" compatibility="5.0.8" expanded="true" height="76" name="Filter Examples (2)" width="90" x="380" y="255">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="Label=0"/>
<operator activated="true" class="filter_examples" compatibility="5.0.8" expanded="true" height="76" name="Filter Examples (4)" width="90" x="246" y="345">
<parameter key="condition_class" value="correct_predictions"/>
<operator activated="true" class="filter_examples" compatibility="5.0.8" expanded="true" height="76" name="Filter Examples (3)" width="90" x="380" y="345">
<parameter key="parameter_string" value="Label=1"/>
<operator activated="true" class="append" compatibility="5.0.8" expanded="true" height="94" name="Append" width="90" x="514" y="255"/>
<operator activated="true" class="select_attributes" compatibility="5.0.8" expanded="true" height="76" name="Select Attributes" width="90" x="648" y="255">
<parameter key="attributes" value="Label|ID|t_92027|t_92026|t_92025|t_92024|t_92023|t_92022|t_92021|t_92020|t_92019|t_92018|t_92017|t_92016|t_92015|t_92014|t_92013|t_92012|t_92011|t_92010|t_92009|t_92008|t_92007|t_92006|t_92005|t_92004|t_92003|t_92002|t_92001|t_91027|t_91026|t_91025|t_91024|t_91023|t_91022|t_91021|t_91020|t_91019|t_91018|t_91017|t_91016|t_91015|t_91014|t_91013|t_91012|t_91011|t_91010|t_91009|t_91008|t_91007|t_91006|t_91005|t_91004|t_91003|t_91002|t_91001|t_90027|t_90026|t_90025|t_90024|t_90023|t_90022|t_90021|t_90020|t_90019|t_90018|t_90017|t_90016|t_90015|t_90014|t_90013|t_90012|t_90011|t_90010|t_90009|t_90008|t_90007|t_90006|t_90005|t_90004|t_90003|t_90002|t_90001|t_82027|t_82026|t_82025|t_82024|t_82023|t_82022|t_82021|t_82020|t_82019|t_82018|t_82017|t_82016|t_82015|t_82014|t_82013|t_82012|t_82011|t_82010|t_82007|t_82006|t_82005|t_82004|t_82003|t_82002|t_82001|t_81027|t_81026|t_81025|t_81024|t_81023|t_81022|t_81021|t_81020|t_81019|t_81018|t_81017|t_81016|t_81015|t_81014|t_81013|t_81012|t_81011|t_81010|t_81007|t_81006|t_81005|t_81004|t_81003|t_81002|t_81001|t_80027|t_80026|t_80025|t_80024|t_80023|t_80022|t_80021|t_80020|t_80019|t_80018|t_80017|t_80016|t_80015|t_80014|t_80013|t_80012|t_80011|t_80010|t_80007|t_80006|t_80005|t_80004|t_80003|t_80002|t_80001"/>
<connect from_port="input 1" to_op="Decision Stump" to_port="training set"/>
<connect from_op="Decision Stump" from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_op="Decision Stump" from_port="exampleSet" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Multiply" to_port="input"/>
<connect from_op="Apply Model (2)" from_port="model" to_port="output 2"/>
<connect from_op="Multiply" from_port="output 1" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 2" to_op="Filter Examples (4)" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Filter Examples (2)" to_port="example set input"/>
<connect from_op="Filter Examples (2)" from_port="example set output" to_op="Append" to_port="example set 1"/>
<connect from_op="Filter Examples (4)" from_port="example set output" to_op="Filter Examples (3)" to_port="example set input"/>
<connect from_op="Filter Examples (3)" from_port="example set output" to_op="Append" to_port="example set 2"/>
<connect from_op="Append" from_port="merged set" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
<portSpacing port="sink_output 3" spacing="0"/>
</process>
<connect from_op="Read AML" from_port="output" to_op="Loop" to_port="input 1"/>
<connect from_op="Loop" from_port="output 1" to_port="result 1"/>
<connect from_op="Loop" from_port="output 2" to_port="result 2"/>
</process>
</process>
This creates two IO collections, one for the model, one for the example set.
However, both models and both example sets, corresponding to the two iterations of the loop look exactly identical.
If I roll-up this process explicitly laying out the two iterations, such as here, this creates the expected results.
Hence, I must conclude that the Loop operator is broken? >:(
<context>
<input/>
<output/>
<macros/>
</context>
<process expanded="true" height="746" width="891">
<operator activated="true" class="decision_stump" compatibility="5.0.8" expanded="true" height="76" name="Decision Stump" width="90" x="179" y="30">
<operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model" width="90" x="313" y="30">
<operator activated="true" class="multiply" compatibility="5.0.8" expanded="true" height="94" name="Multiply (2)" width="90" x="179" y="165"/>
<operator activated="true" class="filter_examples" compatibility="5.0.8" expanded="true" height="76" name="Filter Examples (7)" width="90" x="313" y="255">
<operator activated="true" class="filter_examples" compatibility="5.0.8" expanded="true" height="76" name="Filter Examples (8)" width="90" x="447" y="255">
<operator activated="true" class="filter_examples" compatibility="5.0.8" expanded="true" height="76" name="Filter Examples (5)" width="90" x="313" y="165">
<operator activated="true" class="filter_examples" compatibility="5.0.8" expanded="true" height="76" name="Filter Examples (6)" width="90" x="447" y="165">
<operator activated="true" class="append" compatibility="5.0.8" expanded="true" height="94" name="Append (2)" width="90" x="581" y="210"/>
<operator activated="true" class="select_attributes" compatibility="5.0.8" expanded="true" height="76" name="Select Attributes (2)" width="90" x="715" y="210">
<operator activated="true" class="multiply" compatibility="5.0.8" expanded="true" height="94" name="Multiply" width="90" x="179" y="390"/>
<operator activated="true" class="decision_stump" compatibility="5.0.8" expanded="true" height="76" name="Decision Stump (2)" width="90" x="313" y="390">
<operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model (2)" width="90" x="447" y="390">
<operator activated="true" class="multiply" compatibility="5.0.8" expanded="true" height="94" name="Multiply (3)" width="90" x="179" y="525"/>
<operator activated="true" class="filter_examples" compatibility="5.0.8" expanded="true" height="76" name="Filter Examples (4)" width="90" x="313" y="615">
<operator activated="true" class="filter_examples" compatibility="5.0.8" expanded="true" height="76" name="Filter Examples (9)" width="90" x="447" y="615">
<operator activated="true" class="filter_examples" compatibility="5.0.8" expanded="true" height="76" name="Filter Examples (2)" width="90" x="313" y="525">
<operator activated="true" class="filter_examples" compatibility="5.0.8" expanded="true" height="76" name="Filter Examples (3)" width="90" x="447" y="525">
<operator activated="true" class="append" compatibility="5.0.8" expanded="true" height="94" name="Append (3)" width="90" x="581" y="570"/>
<operator activated="true" class="select_attributes" compatibility="5.0.8" expanded="true" height="76" name="Select Attributes (3)" width="90" x="715" y="570">
<connect from_op="Read AML" from_port="output" to_op="Decision Stump" to_port="training set"/>
<connect from_op="Decision Stump" from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_op="Decision Stump" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Multiply (2)" to_port="input"/>
<connect from_op="Apply Model" from_port="model" to_port="result 1"/>
<connect from_op="Multiply (2)" from_port="output 1" to_op="Filter Examples (5)" to_port="example set input"/>
<connect from_op="Multiply (2)" from_port="output 2" to_op="Filter Examples (7)" to_port="example set input"/>
<connect from_op="Filter Examples (7)" from_port="example set output" to_op="Filter Examples (8)" to_port="example set input"/>
<connect from_op="Filter Examples (8)" from_port="example set output" to_op="Append (2)" to_port="example set 2"/>
<connect from_op="Filter Examples (5)" from_port="example set output" to_op="Filter Examples (6)" to_port="example set input"/>
<connect from_op="Filter Examples (6)" from_port="example set output" to_op="Append (2)" to_port="example set 1"/>
<connect from_op="Append (2)" from_port="merged set" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Decision Stump (2)" to_port="training set"/>
<connect from_op="Multiply" from_port="output 2" to_port="result 3"/>
<connect from_op="Decision Stump (2)" from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_op="Decision Stump (2)" from_port="exampleSet" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Multiply (3)" to_port="input"/>
<connect from_op="Apply Model (2)" from_port="model" to_port="result 2"/>
<connect from_op="Multiply (3)" from_port="output 1" to_op="Filter Examples (2)" to_port="example set input"/>
<connect from_op="Multiply (3)" from_port="output 2" to_op="Filter Examples (4)" to_port="example set input"/>
<connect from_op="Filter Examples (4)" from_port="example set output" to_op="Filter Examples (9)" to_port="example set input"/>
<connect from_op="Filter Examples (9)" from_port="example set output" to_op="Append (3)" to_port="example set 2"/>
<connect from_op="Filter Examples (2)" from_port="example set output" to_op="Filter Examples (3)" to_port="example set input"/>
<connect from_op="Filter Examples (3)" from_port="example set output" to_op="Append (3)" to_port="example set 1"/>
<connect from_op="Append (3)" from_port="merged set" to_op="Select Attributes (3)" to_port="example set input"/>
<connect from_op="Select Attributes (3)" from_port="example set output" to_port="result 4"/>
<portSpacing port="sink_result 5" spacing="0"/>
</process>
</process>
Regards Stefan
