<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="161" width="614"> <operator activated="true" class="generate_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Data" width="90" x="165" y="72"/> <operator activated="true" class="set_role" compatibility="5.0.8" expanded="true" height="76" name="Set Role" width="90" x="339" y="69"> <parameter key="name" value="att1"/> <parameter key="target_role" value="ignore"/> </operator> <operator activated="true" class="support_vector_machine_libsvm" compatibility="5.0.8" expanded="true" height="76" name="SVM" width="90" x="514" y="75"> <parameter key="svm_type" value="epsilon-SVR"/> <list key="class_weights"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
