<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Global"> <parameter key="logfile" value="advanced1.log"/> <process expanded="true" height="766" width="1254"> <operator activated="true" class="read_excel" expanded="true" height="60" name="Read Excel (2)" width="90" x="45" y="120"> <parameter key="excel_file" value="c:\Data\spreedsheet.xls"/> <list key="annotations"/> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role (2)" width="90" x="179" y="120"> <parameter key="name" value="ID"/> <parameter key="target_role" value="id"/> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role (3)" width="90" x="313" y="120"> <parameter key="name" value="target"/> <parameter key="target_role" value="label"/> </operator> <operator activated="true" class="optimize_selection" expanded="true" height="94" name="FS" width="90" x="581" y="30"> <process expanded="true" height="668" width="1094"> <operator activated="true" class="x_validation" expanded="true" height="112" name="XValidation" width="90" x="45" y="75"> <parameter key="number_of_validations" value="5"/> <parameter key="sampling_type" value="shuffled sampling"/> <process expanded="true" height="668" width="522"> <operator activated="true" class="linear_regression" expanded="true" height="76" name="Linear Regression (2)" width="90" x="179" y="120"/> <connect from_port="training" to_op="Linear Regression (2)" to_port="training set"/> <connect from_op="Linear Regression (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="668" width="522"> <operator activated="true" class="apply_model" expanded="true" height="76" name="Applier" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_regression" expanded="true" height="76" name="Performance" width="90" x="179" y="120"> <parameter key="root_mean_squared_error" value="false"/> <parameter key="squared_error" value="true"/> </operator> <connect from_port="model" to_op="Applier" to_port="model"/> <connect from_port="test set" to_op="Applier" to_port="unlabelled data"/> <connect from_op="Applier" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" expanded="true" height="76" name="ProcessLog" width="90" x="581" y="120"> <parameter key="filename" value="c:\data\fs_forward.log"/> <list key="log"> <parameter key="generation" value="operator.FS.value.generation"/> <parameter key="performance" value="operator.FS.value.performance"/> </list> </operator> <connect from_port="example set" to_op="XValidation" to_port="training"/> <connect from_op="XValidation" from_port="averagable 1" to_op="ProcessLog" to_port="through 1"/> <connect from_op="ProcessLog" from_port="through 1" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <operator activated="true" class="write_weights" expanded="true" height="60" name="Write Weights" width="90" x="715" y="165"> <parameter key="attribute_weights_file" value="c:\datar\fs_weights.wgt"/> </operator> <connect from_op="Read Excel (2)" from_port="output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Set Role (3)" to_port="example set input"/> <connect from_op="Set Role (3)" from_port="example set output" to_op="FS" to_port="example set in"/> <connect from_op="FS" from_port="weights" to_op="Write Weights" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
