<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <parameter key="logverbosity" value="3"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="1"/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="parallelize_main_process" value="false"/> <process expanded="true" height="467" width="465"> <operator activated="true" class="generate_churn_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Churn Data" width="90" x="45" y="165"> <parameter key="number_examples" value="1000"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <operator activated="true" class="multiply" compatibility="5.0.8" expanded="true" height="112" name="Multiply" width="90" x="179" y="165"/> <operator activated="true" class="split_validation" compatibility="5.0.8" expanded="true" height="112" name="Validation (2)" width="90" x="313" y="165"> <parameter key="create_complete_model" value="false"/> <parameter key="split" value="1"/> <parameter key="split_ratio" value="0.7"/> <parameter key="training_set_size" value="100"/> <parameter key="test_set_size" value="-1"/> <parameter key="sampling_type" value="1"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="parallelize_training" value="false"/> <parameter key="parallelize_testing" value="false"/> <process expanded="true" height="422" width="243"> <operator activated="true" class="k_nn" compatibility="5.0.8" expanded="true" height="76" name="k-NN" width="90" x="112" y="30"> <parameter key="k" value="5"/> <parameter key="weighted_vote" value="false"/> <parameter key="measure_types" value="0"/> <parameter key="mixed_measure" value="0"/> <parameter key="nominal_measure" value="0"/> <parameter key="numerical_measure" value="0"/> <parameter key="divergence" value="0"/> <parameter key="kernel_type" value="1"/> <parameter key="kernel_gamma" value="1.0"/> <parameter key="kernel_sigma1" value="1.0"/> <parameter key="kernel_sigma2" value="0.0"/> <parameter key="kernel_sigma3" value="2.0"/> <parameter key="kernel_degree" value="3.0"/> <parameter key="kernel_shift" value="1.0"/> <parameter key="kernel_a" value="1.0"/> <parameter key="kernel_b" value="0.0"/> </operator> <connect from_port="training" to_op="k-NN" to_port="training set"/> <connect from_op="k-NN" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="422" width="243"> <operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model (2)" width="90" x="24" y="29"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance" compatibility="5.0.8" expanded="true" height="76" name="Performance (2)" width="90" x="108" y="123"> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="split_validation" compatibility="5.0.8" expanded="true" height="112" name="Validation" width="90" x="313" y="30"> <parameter key="create_complete_model" value="false"/> <parameter key="split" value="1"/> <parameter key="split_ratio" value="0.7"/> <parameter key="training_set_size" value="100"/> <parameter key="test_set_size" value="-1"/> <parameter key="sampling_type" value="stratified sampling"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="parallelize_training" value="false"/> <parameter key="parallelize_testing" value="false"/> <process expanded="true" height="422" width="243"> <operator activated="true" class="decision_tree" compatibility="5.0.8" expanded="true" height="76" name="Decision Tree" width="90" x="45" y="30"> <parameter key="criterion" value="gain_ratio"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_gain" value="0.1"/> <parameter key="maximal_depth" value="20"/> <parameter key="confidence" value="0.25"/> <parameter key="number_of_prepruning_alternatives" value="3"/> <parameter key="no_pre_pruning" value="false"/> <parameter key="no_pruning" value="false"/> </operator> <connect from_port="training" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="422" width="279"> <operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance" compatibility="5.0.8" expanded="true" height="76" name="Performance" width="90" x="112" y="165"> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="split_validation" compatibility="5.0.8" expanded="true" height="130" name="Validation (4)" width="90" x="313" y="300"> <parameter key="create_complete_model" value="false"/> <parameter key="split" value="1"/> <parameter key="split_ratio" value="0.7"/> <parameter key="training_set_size" value="100"/> <parameter key="test_set_size" value="-1"/> <parameter key="sampling_type" value="1"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="parallelize_training" value="false"/> <parameter key="parallelize_testing" value="false"/> <process expanded="true" height="422" width="243"> <operator activated="true" class="naive_bayes" compatibility="5.0.8" expanded="true" height="76" name="Naive Bayes (2)" width="90" x="81" y="30"> <parameter key="laplace_correction" value="true"/> </operator> <connect from_port="training" to_op="Naive Bayes (2)" to_port="training set"/> <connect from_op="Naive Bayes (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="422" width="279"> <operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model (4)" width="90" x="45" y="30"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance" compatibility="5.0.8" expanded="true" height="76" name="Performance (4)" width="90" x="112" y="165"> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="model" to_op="Apply Model (4)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (4)" to_port="unlabelled data"/> <connect from_op="Apply Model (4)" from_port="labelled data" to_op="Performance (4)" to_port="labelled data"/> <connect from_op="Performance (4)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> <portSpacing port="sink_averagable 3" spacing="0"/> </process> </operator> <connect from_op="Generate Churn Data" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Validation" to_port="training"/> <connect from_op="Multiply" from_port="output 2" to_op="Validation (2)" to_port="training"/> <connect from_op="Multiply" from_port="output 3" to_op="Validation (4)" to_port="training"/> <connect from_op="Validation (2)" from_port="averagable 1" to_port="result 4"/> <connect from_op="Validation" from_port="model" to_port="result 1"/> <connect from_op="Validation" from_port="training" to_port="result 2"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 3"/> <connect from_op="Validation (4)" from_port="model" to_port="result 5"/> <connect from_op="Validation (4)" from_port="averagable 1" to_port="result 6"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="108"/> <portSpacing port="sink_result 5" spacing="72"/> <portSpacing port="sink_result 6" spacing="18"/> <portSpacing port="sink_result 7" spacing="0"/> </process> </operator></process>
Just to repeat the question: how do you know which performance corresponds to which model in the result windows?
normally the result tabs show the names of the operators that created the respective result. So you might take a look there?
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="467" width="465"> <operator activated="true" class="generate_churn_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Churn Data" width="90" x="45" y="165"> <parameter key="number_examples" value="1000"/> </operator> <operator activated="true" class="multiply" compatibility="5.0.8" expanded="true" height="112" name="Multiply" width="90" x="179" y="165"/> <operator activated="true" class="split_validation" compatibility="5.0.8" expanded="true" height="112" name="Validation (2)" width="90" x="313" y="165"> <process expanded="true" height="422" width="243"> <operator activated="true" class="k_nn" compatibility="5.0.8" expanded="true" height="76" name="k-NN" width="90" x="112" y="30"> <parameter key="k" value="5"/> </operator> <connect from_port="training" to_op="k-NN" to_port="training set"/> <connect from_op="k-NN" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="422" width="243"> <operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model (2)" width="90" x="24" y="29"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.0.8" expanded="true" height="76" name="B" width="90" x="108" y="123"/> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="B" to_port="labelled data"/> <connect from_op="B" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="split_validation" compatibility="5.0.8" expanded="true" height="112" name="Validation" width="90" x="313" y="30"> <parameter key="sampling_type" value="stratified sampling"/> <process expanded="true" height="422" width="243"> <operator activated="true" class="decision_tree" compatibility="5.0.8" expanded="true" height="76" name="Decision Tree" width="90" x="45" y="30"/> <connect from_port="training" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="422" width="279"> <operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.0.8" expanded="true" height="76" name="A" width="90" x="112" y="165"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="A" to_port="labelled data"/> <connect from_op="A" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="split_validation" compatibility="5.0.8" expanded="true" height="112" name="Validation (4)" width="90" x="313" y="300"> <process expanded="true" height="422" width="243"> <operator activated="true" class="naive_bayes" compatibility="5.0.8" expanded="true" height="76" name="Naive Bayes (2)" width="90" x="81" y="30"/> <connect from_port="training" to_op="Naive Bayes (2)" to_port="training set"/> <connect from_op="Naive Bayes (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="422" width="279"> <operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model (4)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.0.8" expanded="true" height="76" name="C" width="90" x="112" y="165"/> <connect from_port="model" to_op="Apply Model (4)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (4)" to_port="unlabelled data"/> <connect from_op="Apply Model (4)" from_port="labelled data" to_op="C" to_port="labelled data"/> <connect from_op="C" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Generate Churn Data" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Validation" to_port="training"/> <connect from_op="Multiply" from_port="output 2" to_op="Validation (2)" to_port="training"/> <connect from_op="Multiply" from_port="output 3" to_op="Validation (4)" to_port="training"/> <connect from_op="Validation (2)" from_port="averagable 1" to_port="result 4"/> <connect from_op="Validation" from_port="model" to_port="result 1"/> <connect from_op="Validation" from_port="training" to_port="result 2"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 3"/> <connect from_op="Validation (4)" from_port="model" to_port="result 5"/> <connect from_op="Validation (4)" from_port="averagable 1" to_port="result 6"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="108"/> <portSpacing port="sink_result 5" spacing="72"/> <portSpacing port="sink_result 6" spacing="18"/> <portSpacing port="sink_result 7" spacing="0"/> </process> </operator></process>
