<process version="4.6">−<operator name="Root" class="Process" expanded="yes"> <parameter key="resultfile" value="/Users/Antoine/Documents/ISEP/Marketing/webmining/rapidminer46/rapidminer-4.6/myresults.res"/><parameter key="logverbosity" value="init"/><parameter key="random_seed" value="2001"/><parameter key="send_mail" value="never"/><parameter key="process_duration_for_mail" value="30"/><parameter key="encoding" value="SYSTEM"/>−<operator name="LogFileSource" class="LogFileSource"><parameter key="config_file" value="apache.xml"/><parameter key="log_dir" value="logs"/><parameter key="dns_lookup" value="false"/><parameter key="robot_filter" value="robots.txt"/><parameter key="filetype_filter" value="\.[ico|gif|jpg|jpeg|css|js|GIF|JPG|png|PNG|jpg|xml]"/><parameter key="only_HTTP_200" value="true"/><list key="browser_matcher"> </list>−<list key="os_matcher"><parameter key="windows" value="(.*)(Windows|windows|WINDOWS)(.*)"/><parameter key="unix" value="(Linux|Unix|unix|UNIX)(.*)"/><parameter key="mac" value="(.*)(Mac|OS X)(.*)"/></list><list key="language_matcher"> </list><parameter key="session_timeout" value="400000"/></operator></operator></process>
<?xml version="1.0" encoding="MacRoman"?><process version="4.6"> <operator name="Root" class="Process" expanded="yes"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> </operator></process>
<operator name="Root" class="Process" expanded="yes"> <parameter key="resultfile" value="/Users/Antoine/Documents/ISEP/Marketing/webmining/rapidminer46/rapidminer-4.6/myresults.res"/> <operator name="LogFileSource" class="LogFileSource"> <parameter key="config_file" value="c:\apache.xml"/> <parameter key="log_dir" value="c:\logs"/> <parameter key="robot_filter" value="c:\robots.txt"/> <parameter key="filetype_filter" value="\.[ico|gif|jpg|jpeg|css|js|GIF|JPG|png|PNG|jpg|xml]"/> <parameter key="only_HTTP_200" value="true"/> <list key="browser_matcher"> </list> <list key="os_matcher"> <parameter key="windows" value="(.*)(Windows|windows|WINDOWS)(.*)"/> <parameter key="unix" value="(Linux|Unix|unix|UNIX)(.*)"/> <parameter key="mac" value="(.*)(Mac|OS X)(.*)"/> </list> <list key="language_matcher"> </list> </operator></operator>
