<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="-20" width="-50"> <operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV" width="90" x="18" y="90"> <parameter key="file_name" value="C:\Documents and Settings\Alien\My Documents\rm_workspace\R5 Forum\fdata.csv"/> <parameter key="use_first_row_as_attribute_names" value="false"/> </operator> <operator activated="true" breakpoints="before" class="guess_types" expanded="true" height="76" name="Guess Types" width="90" x="199" y="87"/> <connect from_op="Read CSV" from_port="output" to_op="Guess Types" to_port="example set input"/> <connect from_op="Guess Types" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
