<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="296" width="1018"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="150"/> <parameter key="use_local_random_seed" value="true"/> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename" width="90" x="179" y="30"> <parameter key="old_name" value="att1"/> <parameter key="new_name" value="Flight"/> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename (2)" width="90" x="313" y="30"> <parameter key="old_name" value="att2"/> <parameter key="new_name" value="Date"/> </operator> <operator activated="true" class="numerical_to_polynominal" expanded="true" height="76" name="Numerical to Polynominal" width="90" x="447" y="30"/> <operator activated="true" class="generate_attributes" expanded="true" height="76" name="Generate Attributes" width="90" x="581" y="30"> <list key="function_descriptions"> <parameter key="FlightDate" value="Flight + " - " + Date"/> </list> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="715" y="30"> <parameter key="name" value="FlightDate"/> <parameter key="target_role" value="id"/> </operator> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data (2)" width="90" x="45" y="210"> <parameter key="use_local_random_seed" value="true"/> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename (3)" width="90" x="175" y="210"> <parameter key="old_name" value="att1"/> <parameter key="new_name" value="Flight"/> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename (4)" width="90" x="310" y="210"> <parameter key="old_name" value="att2"/> <parameter key="new_name" value="Date"/> </operator> <operator activated="true" class="numerical_to_polynominal" expanded="true" height="76" name="Numerical to Polynominal (2)" width="90" x="445" y="210"/> <operator activated="true" class="generate_attributes" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="580" y="210"> <list key="function_descriptions"> <parameter key="FlightDate" value="Flight + " - " + Date"/> </list> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role (2)" width="90" x="715" y="210"> <parameter key="name" value="FlightDate"/> <parameter key="target_role" value="id"/> </operator> <operator activated="true" class="join" expanded="true" height="76" name="Join" width="90" x="916" y="75"/> <connect from_op="Generate Data" from_port="output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Numerical to Polynominal" to_port="example set input"/> <connect from_op="Numerical to Polynominal" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Generate Data (2)" from_port="output" to_op="Rename (3)" to_port="example set input"/> <connect from_op="Rename (3)" from_port="example set output" to_op="Rename (4)" to_port="example set input"/> <connect from_op="Rename (4)" from_port="example set output" to_op="Numerical to Polynominal (2)" to_port="example set input"/> <connect from_op="Numerical to Polynominal (2)" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
