Hi everyone,
I'm trying to find a way to pass input arguments into hyperstudy instead of specifying it in the script.bat for the madymo solver. In other words, I know that writing:
"-i inputfilename.xml"
in the script.bat I created for madymo execution is good enough to start the simulation properly, but it's a little bit tricky as you have to change .bat file everytime the model_name is edited. Is it feasible passing the inputfilename directly in hyperstudy in a parametrized way in order to overcome this issue?
I know that
${filename}
is the natural way to do so, but as it doesn't work, I assume there's a need for more.
The HyperStudy User guide tells me to write down -fg <filename>.xml, but this still doesn't work.
Many thanks
