<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Root"> <parameter key="parallelize_main_process" value="true"/> <process expanded="true" height="611" width="748"> <operator activated="true" class="read_database" expanded="true" height="60" name="Input Anst alle t" width="90" x="45" y="30"> <parameter key="define_connection" value="url"/> <parameter key="database_system" value="ODBC Bridge (e.g. Access)"/> <parameter key="database_url" value="jdbc:odbc:Driver={Microsoft Access-Treiber (*.mdb)};DBQ=c:\users\Papa\rapid-i\rethw08\re35118a.mdb"/> <parameter key="username" value="Admin"/> <parameter key="password" value="HqBOhGwNZxQ="/> <parameter key="query" value="SELECT lfdnr, t, Ansprache as Anst FROM "ret35a" order by lfdnr,t "/> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role lfdnr id" width="90" x="179" y="30"> <parameter key="name" value="lfdnr"/> <parameter key="target_role" value="id"/> </operator> <operator activated="true" class="read_database" expanded="true" height="60" name="Input Ansprache Schluß" width="90" x="45" y="165"> <parameter key="define_connection" value="url"/> <parameter key="database_system" value="ODBC Bridge (e.g. Access)"/> <parameter key="database_url" value="jdbc:odbc:Driver={Microsoft Access-Treiber (*.mdb)};DBQ=c:\users\Papa\rapid-i\rethw08\re35118a.mdb"/> <parameter key="username" value="Admin"/> <parameter key="password" value="HqBOhGwNZxQ="/> <parameter key="query" value="SELECT lfdnr, Ansprache FROM "ret35a" Where T=248 "/> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role lfdnr id 1" width="90" x="179" y="165"> <parameter key="name" value="lfdnr"/> <parameter key="target_role" value="id"/> </operator> <operator activated="true" class="join" expanded="true" height="76" name="Join" width="90" x="313" y="75"/> <operator activated="true" class="read_database" expanded="true" height="60" name="Input Promotions" width="90" x="45" y="345"> <parameter key="define_connection" value="url"/> <parameter key="database_system" value="ODBC Bridge (e.g. Access)"/> <parameter key="database_url" value="jdbc:odbc:Driver={Microsoft Access-Treiber (*.mdb)};DBQ=c:\users\Papa\rapid-i\art118.mdb"/> <parameter key="username" value="Admin"/> <parameter key="password" value="HqBOhGwNZxQ="/> <parameter key="query" value="SELECT * FROM "Promotions" WHERE ka='35'"/> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role orig id" width="90" x="246" y="345"> <parameter key="name" value="lfdnr"/> <parameter key="target_role" value="id"/> </operator> <operator activated="true" class="join" expanded="true" height="76" name="Join (2)" width="90" x="514" y="165"/> <connect from_op="Input Anst alle t" from_port="output" to_op="Set Role lfdnr id" to_port="example set input"/> <connect from_op="Set Role lfdnr id" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Input Ansprache Schluß" from_port="output" to_op="Set Role lfdnr id 1" to_port="example set input"/> <connect from_op="Set Role lfdnr id 1" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Join (2)" to_port="left"/> <connect from_op="Input Promotions" from_port="output" to_op="Set Role orig id" to_port="example set input"/> <connect from_op="Set Role orig id" from_port="example set output" to_op="Join (2)" to_port="right"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Root"> <process expanded="true" height="611" width="748"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="generate_id" expanded="true" height="76" name="Generate ID" width="90" x="179" y="30"/> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data (2)" width="90" x="45" y="165"/> <operator activated="true" class="generate_id" expanded="true" height="76" name="Generate ID (2)" width="90" x="168" y="177"/> <operator activated="true" class="join" expanded="true" height="76" name="Join" width="90" x="313" y="75"/> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data (3)" width="90" x="45" y="345"/> <operator activated="true" class="generate_id" expanded="true" height="76" name="Generate ID (3)" width="90" x="201" y="343"/> <operator activated="true" class="join" expanded="true" height="76" name="Join (2)" width="90" x="514" y="165"/> <connect from_op="Generate Data" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Generate Data (2)" from_port="output" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Join (2)" to_port="left"/> <connect from_op="Generate Data (3)" from_port="output" to_op="Generate ID (3)" to_port="example set input"/> <connect from_op="Generate ID (3)" from_port="example set output" to_op="Join (2)" to_port="right"/> <connect from_op="Join (2)" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="646" width="714"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"> <parameter key="target_function" value="spiral cluster"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator activated="true" class="generate_id" expanded="true" height="76" name="Generate ID" width="90" x="216" y="85"/> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data (2)" width="90" x="45" y="210"> <parameter key="target_function" value="spiral cluster"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator activated="true" class="generate_id" expanded="true" height="76" name="Generate ID (2)" width="90" x="213" y="270"/> <operator activated="true" class="rename" expanded="true" height="76" name="Rename" width="90" x="380" y="300"> <parameter key="old_name" value="id"/> <parameter key="new_name" value="i5"/> </operator> <operator activated="true" class="join" expanded="true" height="76" name="Join" width="90" x="514" y="165"/> <connect from_op="Generate Data" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Generate Data (2)" from_port="output" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Join" to_port="right"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="514" width="719"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"> <parameter key="target_function" value="spiral cluster"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator activated="true" class="generate_id" expanded="true" height="76" name="Generate ID" width="90" x="216" y="85"/> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data (2)" width="90" x="45" y="210"> <parameter key="target_function" value="spiral cluster"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator activated="true" class="generate_id" expanded="true" height="76" name="Generate ID (2)" width="90" x="179" y="210"/> <operator activated="true" class="rename" expanded="true" height="76" name="Rename" width="90" x="313" y="210"> <parameter key="old_name" value="id"/> <parameter key="new_name" value="i5"/> </operator> <operator activated="true" class="read_excel" expanded="true" height="60" name="Read Excel" width="90" x="30" y="363"> <parameter key="excel_file" value="C:\Users\Papa\Documents\rm_workspace\Meine Daten\test.xls"/> </operator> <operator activated="true" class="generate_id" expanded="true" height="76" name="Generate ID (3)" width="90" x="179" y="345"/> <operator activated="true" class="rename" expanded="true" height="76" name="Rename (2)" width="90" x="380" y="345"> <parameter key="old_name" value="id"/> <parameter key="new_name" value="i6"/> </operator> <operator activated="true" class="join" expanded="true" height="76" name="Join (2)" width="90" x="581" y="255"/> <operator activated="true" class="join" expanded="true" height="76" name="Join" width="90" x="514" y="120"/> <connect from_op="Generate Data" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Generate Data (2)" from_port="output" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Join (2)" to_port="left"/> <connect from_op="Read Excel" from_port="output" to_op="Generate ID (3)" to_port="example set input"/> <connect from_op="Generate ID (3)" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Join (2)" to_port="right"/> <connect from_op="Join (2)" from_port="join" to_op="Join" to_port="right"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="767" width="902"> <operator activated="true" class="read_excel" expanded="true" height="60" name="Read Excel" width="90" x="45" y="165"> <parameter key="excel_file" value="C:\Users\XXX\Documents\Daten\DataGenA.xls"/> <parameter key="row_offset" value="1"/> </operator> <operator activated="true" class="read_excel" expanded="true" height="60" name="Read Excel (2)" width="90" x="45" y="255"> <parameter key="excel_file" value="C:\Users\XXX\Documents\Daten\DataGenB.xls"/> </operator> <operator activated="true" class="generate_attributes" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="165"> <list key="function_descriptions"> <parameter key="Origin" value=""A""/> </list> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename" width="90" x="313" y="165"> <parameter key="old_name" value="IDGen_ID"/> <parameter key="new_name" value="GenID"/> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="447" y="165"> <parameter key="name" value="GenID"/> <parameter key="target_role" value="id"/> </operator> <operator activated="true" class="generate_attributes" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="179" y="255"> <list key="function_descriptions"> <parameter key="Origin" value=""B""/> </list> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename (2)" width="90" x="313" y="255"> <parameter key="old_name" value="IDGen_ID"/> <parameter key="new_name" value="GenID"/> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role (2)" width="90" x="447" y="255"> <parameter key="name" value="GenID"/> <parameter key="target_role" value="id"/> </operator> <operator activated="true" class="subprocess" expanded="true" height="112" name="Merge" width="90" x="581" y="165"> <process expanded="true" height="767" width="902"> <operator activated="true" class="multiply" expanded="true" height="112" name="Multiply (3)" width="90" x="45" y="30"/> <operator activated="true" class="multiply" expanded="true" height="112" name="Multiply (4)" width="90" x="45" y="165"/> <operator activated="true" class="set_minus" expanded="true" height="76" name="Set Minus (3)" width="90" x="179" y="210"/> <operator activated="true" class="multiply" expanded="true" height="94" name="Multiply (26)" width="90" x="313" y="255"/> <operator activated="true" class="join" expanded="true" height="76" name="Join (2)" width="90" x="179" y="120"> <parameter key="remove_double_attributes" value="false"/> </operator> <operator activated="true" class="set_minus" expanded="true" height="76" name="Set Minus" width="90" x="179" y="30"/> <operator activated="true" class="multiply" expanded="true" height="94" name="Multiply" width="90" x="313" y="30"/> <operator activated="true" class="union" expanded="true" height="76" name="Union" width="90" x="447" y="75"/> <operator activated="true" class="union" expanded="true" height="76" name="Union (3)" width="90" x="581" y="120"/> <connect from_port="in 1" to_op="Multiply (3)" to_port="input"/> <connect from_port="in 2" to_op="Multiply (4)" to_port="input"/> <connect from_op="Multiply (3)" from_port="output 1" to_op="Set Minus" to_port="example set input"/> <connect from_op="Multiply (3)" from_port="output 2" to_op="Join (2)" to_port="left"/> <connect from_op="Multiply (3)" from_port="output 3" to_op="Set Minus (3)" to_port="subtrahend"/> <connect from_op="Multiply (4)" from_port="output 1" to_op="Set Minus" to_port="subtrahend"/> <connect from_op="Multiply (4)" from_port="output 2" to_op="Join (2)" to_port="right"/> <connect from_op="Multiply (4)" from_port="output 3" to_op="Set Minus (3)" to_port="example set input"/> <connect from_op="Set Minus (3)" from_port="example set output" to_op="Multiply (26)" to_port="input"/> <connect from_op="Multiply (26)" from_port="output 1" to_port="out 3"/> <connect from_op="Multiply (26)" from_port="output 2" to_op="Union (3)" to_port="example set 2"/> <connect from_op="Join (2)" from_port="join" to_op="Union" to_port="example set 2"/> <connect from_op="Set Minus" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_port="out 2"/> <connect from_op="Multiply" from_port="output 2" to_op="Union" to_port="example set 1"/> <connect from_op="Union" from_port="union" to_op="Union (3)" to_port="example set 1"/> <connect from_op="Union (3)" from_port="union" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="source_in 3" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> <portSpacing port="sink_out 3" spacing="0"/> <portSpacing port="sink_out 4" spacing="0"/> </process> </operator> <operator activated="true" class="collect" expanded="true" height="94" name="MergeDiff" width="90" x="581" y="30"/> <connect from_op="Read Excel" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Read Excel (2)" from_port="output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Merge" to_port="in 1"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Merge" to_port="in 2"/> <connect from_op="Merge" from_port="out 1" to_port="result 2"/> <connect from_op="Merge" from_port="out 2" to_op="MergeDiff" to_port="input 1"/> <connect from_op="Merge" from_port="out 3" to_op="MergeDiff" to_port="input 2"/> <connect from_op="MergeDiff" from_port="collection" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
