I am trying to setup a process in RapidMiner for text mining that uses SVDs. I have compared the time it takes to create SVDs using the entire dataset and for only a training set (within the training subprocess of an X-Validation operator). (Both processes I used are detailed below.) Using the entire dataset, the entire process finishes within a minute or so. When running the process with an X-Validation operator, the time increases dramatically; after 45 minutes the SVDs had not been created. Any ideas on why creating SVDs is taking so much longer inside the X-Validation operator?
For both processes I am using the comp.graphics and comp.windows.x newsgroups mini-datasets available from
http://archive.ics.uci.edu/ml/databases/20newsgroups/20newsgroups.html (mini_newsgroups.tar.gz).
Entire Dataset:
<process version="5.0">
<context>
<input>
<location/>
</input>
<output>
<location/>
<location/>
<location/>
<location/>
</output>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<process expanded="true" height="521" width="614">
<operator activated="true" class="text:process_document_from_file" expanded="true" height="76" name="Process Documents from Files" width="90" x="112" y="75">
<list key="text_directories">
<parameter key="comp.graphics" value="/misc_datasets/mini_newsgroups/comp.graphics"/>
<parameter key="comp.windows.x" value="/misc_datasets/mini_newsgroups/comp.windows.x"/>
</list>
<parameter key="vector_creation" value="Term Occurrences"/>
<parameter key="prune_method" value="absolute"/>
<parameter key="prune_below_absolute" value="2"/>
<parameter key="prune_above_absolute" value="200"/>
<process expanded="true" height="650" width="1092">
<operator activated="true" class="text:transform_cases" expanded="true" height="60" name="Transform Cases" width="90" x="73" y="30"/>
<operator activated="true" class="text:tokenize" expanded="true" height="60" name="Tokenize" width="90" x="246" y="30"/>
<operator activated="true" class="text:filter_by_length" expanded="true" height="60" name="Filter by Length" width="90" x="380" y="30">
<parameter key="min_chars" value="2"/>
<parameter key="max_chars" value="50"/>
<connect from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter by Length" to_port="document"/>
<connect from_op="Filter by Length" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="generate_tfidf" expanded="true" height="76" name="Generate TFIDF" width="90" x="313" y="165"/>
<operator activated="true" class="singular_value_decomposition" expanded="true" height="94" name="SVD" width="90" x="447" y="165">
<parameter key="return_preprocessing_model" value="true"/>
<parameter key="dimensions" value="100"/>
<connect from_op="Process Documents from Files" from_port="example set" to_op="Generate TFIDF" to_port="example set input"/>
<connect from_op="Process Documents from Files" from_port="word list" to_port="result 3"/>
<connect from_op="Generate TFIDF" from_port="example set output" to_op="SVD" to_port="example set input"/>
<connect from_op="SVD" from_port="example set output" to_port="result 1"/>
<connect from_op="SVD" from_port="preprocessing model" to_port="result 2"/>
</process>
</process>
X-Validation:
Note: I tried putting a Materialize Data operator in before creating the SVDs, but it doesn't seem to speed up the creation of the SVDs.
<context>
<input>
<location/>
</input>
<output>
<location/>
<location/>
<location/>
</output>
<macros/>
</context>
</list>
</process>
<operator activated="true" class="x_validation" expanded="true" height="112" name="Validation" width="90" x="246" y="300">
<process expanded="true" height="650" width="614">
<operator activated="true" class="generate_tfidf" expanded="true" height="76" name="Generate TFIDF" width="90" x="45" y="30"/>
<operator activated="true" class="materialize_data" expanded="true" height="76" name="Materialize Data" width="90" x="179" y="30">
<parameter key="datamanagement" value="double_sparse_array"/>
<operator activated="true" class="singular_value_decomposition" expanded="true" height="94" name="SVD" width="90" x="313" y="30">
<operator activated="true" class="logistic_regression" expanded="true" height="94" name="Logistic Regression" width="90" x="447" y="30"/>
<connect from_port="training" to_op="Generate TFIDF" to_port="example set input"/>
<connect from_op="Generate TFIDF" from_port="example set output" to_op="Materialize Data" to_port="example set input"/>
<connect from_op="Materialize Data" from_port="example set output" to_op="SVD" to_port="example set input"/>
<connect from_op="SVD" from_port="example set output" to_op="Logistic Regression" to_port="training set"/>
<connect from_op="SVD" from_port="preprocessing model" to_port="through 1"/>
<connect from_op="Logistic Regression" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
<portSpacing port="sink_through 2" spacing="0"/>
</process>
<process expanded="true" height="650" width="547">
<operator activated="true" class="generate_tfidf" expanded="true" height="76" name="Generate TFIDF (2)" width="90" x="45" y="30"/>
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="179" y="30">
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model (2)" width="90" x="313" y="30">
<operator activated="true" class="performance_binominal_classification" expanded="true" height="76" name="Performance" width="90" x="380" y="165">
<parameter key="main_criterion" value="f_measure"/>
<parameter key="AUC (optimistic)" value="true"/>
<parameter key="precision" value="true"/>
<parameter key="recall" value="true"/>
<parameter key="lift" value="true"/>
<parameter key="fallout" value="true"/>
<parameter key="f_measure" value="true"/>
<parameter key="false_positive" value="true"/>
<parameter key="false_negative" value="true"/>
<parameter key="true_positive" value="true"/>
<parameter key="true_negative" value="true"/>
<parameter key="sensitivity" value="true"/>
<parameter key="specificity" value="true"/>
<parameter key="youden" value="true"/>
<parameter key="positive_predictive_value" value="true"/>
<parameter key="negative_predictive_value" value="true"/>
<parameter key="psep" value="true"/>
<connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_port="test set" to_op="Generate TFIDF (2)" to_port="example set input"/>
<connect from_port="through 1" to_op="Apply Model" to_port="model"/>
<connect from_op="Generate TFIDF (2)" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="source_through 2" spacing="0"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_op="Process Documents from Files" from_port="example set" to_op="Validation" to_port="training"/>
<connect from_op="Process Documents from Files" from_port="word list" to_port="result 1"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 2"/>
</process>
</process>
Any help would be greatly appreciated. Thanks!
