Hi there,
I'm kind of new to Rapidminer.
I develop a Java Application that gets some data from a database and applies a model, that is already learned or a whole RapidMiner process that is designed in the RapidMiner GUI.
Especially in the case of the process, I'd like to map the attributes between the database and the desired input for the process or the model, that should be applied (it should work generic, so the mapping particulary is done manually).
Is it possible, to get knownledge of the attributes the model or process needs?
Can I fill data into a ExampleSet of a defined Process with a stream?
Thanks for help,
(and greetings from Dortmund
Markus
