<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="-20" width="-50"> <operator activated="true" class="read_arff" expanded="true" height="60" name="Read ARFF" width="90" x="61" y="74"> <parameter key="data_file" value="C:\Documents and Settings\Alien\My Documents\rm_workspace\test.arff"/> <parameter key="label_attribute" value="label"/> </operator> <connect from_op="Read ARFF" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="36"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
