<operator name="Root" class="Process" expanded="yes"> <operator name="ChurnReductionExampleSetGenerator" class="ChurnReductionExampleSetGenerator"> </operator> <operator name="IOMultiplier" class="IOMultiplier"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="IOSelector" class="IOSelector"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="ExampleFilter" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="label = terminate"/> </operator> <operator name="Bootstrapping" class="Bootstrapping"> <parameter key="sample_ratio" value="13.28"/> </operator> <operator name="IOSelector (2)" class="IOSelector"> <parameter key="io_object" value="ExampleSet"/> <parameter key="select_which" value="2"/> </operator> <operator name="ExampleFilter (2)" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="label = ok"/> </operator> <operator name="ExampleSetMerge" class="ExampleSetMerge"> </operator></operator>
