Hi all
I want to use centers of clusters in each class as new data to reduce number of the samples:
as far as I know I should make an iteration among classes and in each class make a cluster and uses centers of clusters as a new sample.
but I do not know how? I made a draft code but I works just to filtering and clustering and it is not able to use and save them.
Regards
REZA
<operator name="ExampleSetGenerator" class="ExampleSetGenerator">
<parameter key="target_function" value="polynomial classification"/>
<parameter key="number_examples" value="1000"/>
<parameter key="number_of_attributes" value="20"/>
<operator name="Normalization" class="Normalization">
<parameter key="create_view" value="true"/>
<operator name="protyper" class="OperatorChain" expanded="yes">
<operator name="ValueIterator (2)" class="ValueIterator" expanded="yes">
<parameter key="attribute" value="label"/>
<operator name="ExampleFilter (3)" class="ExampleFilter">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="label = %{loop_value}"/>
<operator name="KMeans" class="KMeans">
<parameter key="keep_example_set" value="false"/>
<parameter key="k" value="4"/>
<operator name="ExceptionHandling" class="ExceptionHandling" expanded="yes">
<operator name="ExampleSetMerge (2)" class="ExampleSetMerge">
<operator name="IOConsumer (2)" class="IOConsumer" breakpoints="after">
<parameter key="io_object" value="ClusterModel"/>
<operator name="Final Retrieve (2)" class="IORetriever">
<parameter key="name" value="Cluster Model"/>
<operator name="In every case: Store (2)" class="IOStorer">
