"Attribute and SVM"
Savaju
Savaju New Altair Community Member
Hello
I have just started to use rapidminer in my PhD I believed, it is a powerful tool but also I have had my first "big problem"
I want to use SVM and I need to import the data but I have some problems with the labels of this data
[tt]Learning methods require the input example sets to have at least one attribute. If this not the case, applying these operators is pointless. Certain operators like feature selection operators may switch off all attributes. If this happens, learning schemes cannot be applied.[/tt]
I followed this thread http://rapid-i.com/rapidforum/index.php?action=printpage;topic=105.0, But I can not solve the problem
This is my code
    <parameter key="logfile" value="D:\Tesis\Pruebas\Prueba1_SVM.log"/>
    <parameter key="resultfile" value="D:\Tesis\Pruebas\Fichero_resultados_1.res"/>
    <operator name="CSVExampleSource" class="CSVExampleSource">
        <parameter key="filename" value="D:\Tesis\Pruebas\autovalores4.csv"/>
        <parameter key="label_name" value="autovalores1"/>
    <operator name="ChangeAttributeRole" class="ChangeAttributeRole">
        <parameter key="name" value="Autovalores1"/>
    <operator name="CSVExampleSource (2)" class="CSVExampleSource">
        <parameter key="filename" value="D:\Tesis\Pruebas\autovalores5.csv"/>
        <parameter key="label_name" value="Autovalores2"/>
    <operator name="ChangeAttributeRole (2)" class="ChangeAttributeRole">
        <parameter key="name" value="Autovalores2"/>
    <operator name="SimpleValidation" class="SimpleValidation" expanded="yes">
        <operator name="PsoSVM" class="PsoSVM">
        <operator name="OperatorChain" class="OperatorChain" expanded="yes">
            <operator name="ModelApplier" class="ModelApplier">
                <list key="application_parameters">
                </list>
            <operator name="Performance" class="Performance">
Thank you in advance
Juan
  • haddock
    haddock New Altair Community Member
    Hi there,
    How many columns of data do you have in "D:\Tesis\Pruebas\autovalores5.csv"?
  • land
    land New Altair Community Member
    one obvious thing and potential problem in your process is as follows:
    You are loading two different example sets in your process. The SVM will work on only one example set and that is the last you loaded. If you want to train on both sets, you will have to merge them.
    Greetings,
      Sebastian
Welcome!
Welcome!
