<operator name="Root" class="Process" expanded="yes"> <description text="Datensatz: doy_sz1_chlalt_ausreisser_aisa_mean1.amlE:\v_rapid_min\v_rapid_eschen1\v_chl_aisa_modell\"/> <operator name="Daten laden und vorbereiten" class="OperatorChain" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="sum"/> <parameter key="number_of_attributes" value="100"/> </operator> </operator> <operator name="Attribute identifizieren, Ranking, Correalation" class="OperatorChain" expanded="yes"> <operator name="SVMWeighting" class="SVMWeighting"> </operator> <operator name="AttributeWeightSelection" class="AttributeWeightSelection"> <parameter key="keep_attribute_weights" value="true"/> <parameter key="weight" value="0.0"/> </operator> <operator name="CorrelationMatrix - 1" class="CorrelationMatrix"> </operator> <operator name="RemoveCorrelatedFeatures 1" class="RemoveCorrelatedFeatures"> <parameter key="correlation" value="0.1"/> <parameter key="attribute_order" value="random"/> </operator> <operator name="RemoveCorrelatedFeatures 2" class="RemoveCorrelatedFeatures"> <parameter key="correlation" value="-0.1"/> <parameter key="attribute_order" value="random"/> </operator> <operator name="CorrelationMatrix - 2" class="CorrelationMatrix"> </operator> </operator> <operator name="Mehrmals ausführen, bestes behalten" class="RandomOptimizer" expanded="yes"> <parameter key="iterations" value="100"/> <operator name="Kreuzvalidierung zur Performanzschätzung" class="XValidation" expanded="yes"> <parameter key="sampling_type" value="shuffled sampling"/> <operator name="LinearRegression (2)" class="LinearRegression"> </operator> <operator name="NeuralNetImproved" class="NeuralNetImproved" activated="no"> <list key="hidden_layers"> </list> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="ModelApplier (2)" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="RegressionPerformance" class="RegressionPerformance"> <parameter key="root_mean_squared_error" value="true"/> <parameter key="absolute_error" value="true"/> <parameter key="relative_error" value="true"/> <parameter key="skip_undefined_labels" value="false"/> <parameter key="use_example_weights" value="false"/> </operator> </operator> </operator> </operator></operator>
