<operator name="Root" class="Process" expanded="yes"> <operator name="FileIterator" class="FileIterator" expanded="yes"> <parameter key="directory" value="C:\Test"/> <parameter key="filter" value=".*arff"/> <operator name="ExceptionHandling" class="ExceptionHandling" expanded="yes"> <operator name="IORetriever" class="IORetriever"> <parameter key="name" value="ES"/> <parameter key="io_object" value="ExampleSet"/> </operator> </operator> <operator name="ArffExampleSource" class="ArffExampleSource"> <parameter key="data_file" value="%{file_path}"/> </operator> <operator name="ExampleSetMerge" class="ExampleSetMerge"> </operator> <operator name="IOStorer" class="IOStorer"> <parameter key="name" value="ES"/> <parameter key="io_object" value="ExampleSet"/> </operator> </operator> <operator name="IORetriever (2)" class="IORetriever"> <parameter key="name" value="ES"/> <parameter key="io_object" value="ExampleSet"/> </operator></operator>
