<operator name="Root" class="Process" expanded="yes"> <operator name="DatabaseExampleSource" class="DatabaseExampleSource"> </operator> <operator name="GA" class="GeneticAlgorithm" expanded="yes"> <operator name="XVal" class="XValidation" expanded="yes"> <operator name="Learner" class="LibSVMLearner"> <list key="class_weights"> </list> </operator> <operator name="ApplierChain" class="OperatorChain" expanded="yes"> <operator name="Applier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="Evaluator" class="Performance"> </operator> </operator> </operator> </operator></operator>
<operator name="DatabaseExampleSource" class="DatabaseExampleSource"> <parameter key="database_system" value="Microsoft SQL Server (Microsoft)"/> <parameter key="database_url" value="jdbc:sqlserver://KEITHS_DB"/> <parameter key="username" value="keith"/> <parameter key="password" value="BTs7lFuaeWCRLJzv8cWy6g=="/> <parameter key="query" value="select * from mytable"/> </operator>
<operator name="Root" class="Process" expanded="yes"> <operator name="DatabaseExampleSource" class="DatabaseExampleSource" breakpoints="after"> <parameter key="work_on_database" value="true"/> <parameter key="database_url" value="jdbc:derby://localhost:1527/reducedFeatureDB"/> <parameter key="username" value="user1"/> <parameter key="password" value="e7QsjGOrCv4="/> <parameter key="query" value="select * from location"/> <parameter key="table_name" value="LOCATION"/> <parameter key="label_attribute" value="NUM"/> </operator> <operator name="GA" class="GeneticAlgorithm" expanded="yes"> <operator name="XVal" class="XValidation" expanded="yes"> <operator name="NearestNeighbors" class="NearestNeighbors"> </operator> <operator name="ApplierChain" class="OperatorChain" expanded="yes"> <operator name="Applier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="Evaluator" class="Performance"> </operator> </operator> </operator> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <operator name="DatabaseExampleSource" class="DatabaseExampleSource" breakpoints="after"> <parameter key="work_on_database" value="true"/> <parameter key="database_url" value="jdbc:derby://localhost:1527/reducedFeatureDB"/> <parameter key="username" value="user1"/> <parameter key="password" value="e7QsjGOrCv4="/> <parameter key="query" value="select feat0 from location"/> <parameter key="table_name" value="LOCATION"/> <parameter key="label_attribute" value="NUM"/> </operator> <operator name="GA" class="GeneticAlgorithm" expanded="yes"> <operator name="XVal" class="XValidation" expanded="yes"> <operator name="NearestNeighbors" class="NearestNeighbors"> </operator> <operator name="ApplierChain" class="OperatorChain" expanded="yes"> <operator name="Applier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="Evaluator" class="Performance"> </operator> </operator> </operator> </operator></operator>
