<operator name="Root" class="Process" expanded="yes"> <description text="Simply generates a sinus series and displays it."/> <operator name="SinusGenerator" class="SinusGenerator"> <parameter key="number_of_values" value="1000"/> <list key="frequency"> <parameter key="120" value="1.0"/> <parameter key="200" value="1.0"/> <parameter key="310" value="1.0"/> </list> </operator> <operator name="FastFourierTransform" class="FastFourierTransform"> <parameter key="frequency_rescaling" value="true"/> <parameter key="sample_rate" value="1000.0"/> </operator> <operator name="SeriesObject2ExampleSet" class="SeriesObject2ExampleSet"> </operator> <operator name="AttributeCopy" class="AttributeCopy"> <parameter key="attribute_name" value="FFT(sinus)_index"/> <parameter key="new_name" value="frequency"/> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <description text="Simply generates a sinus series and displays it."/> <operator name="SinusGenerator" class="SinusGenerator"> <parameter key="number_of_values" value="1000"/> <list key="frequency"> <parameter key="120" value="1.0"/> <parameter key="200" value="1.0"/> <parameter key="310" value="1.0"/> </list> </operator> <operator name="FastFourierTransform" class="FastFourierTransform"> <parameter key="frequency_rescaling" value="true"/> <parameter key="sample_rate" value="1000.0"/> </operator> <operator name="SeriesObject2ExampleSet" class="SeriesObject2ExampleSet"> </operator> <operator name="AttributeCopy" class="AttributeCopy"> <parameter key="attribute_name" value="FFT(sinus)_index"/> <parameter key="new_name" value="frequency"/> </operator> <operator name="Change frequency to label" class="ChangeAttributeRole"> <parameter key="name" value="frequency"/> <parameter key="target_role" value="label"/> </operator> <operator name="Remove brackets so construction works" class="AttributeCopy"> <parameter key="attribute_name" value="FFT(sinus)_dim_1"/> <parameter key="new_name" value="value"/> </operator> <operator name="AttributeConstruction" class="AttributeConstruction"> <list key="function_descriptions"> <parameter key="filteredFFTResult" value="if (frequency > 175 && frequency < 225, value,0)"/> </list> <parameter key="use_standard_constants" value="false"/> <parameter key="keep_all" value="false"/> </operator></operator>
