<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="494" width="752"> <operator activated="true" class="generate_data" compatibility="5.2.006" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="three ring clusters"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator activated="true" class="polynomial_by_binomial_classification" compatibility="5.2.006" expanded="true" height="76" name="Polynominal by Binominal Classification" width="90" x="246" y="30"> <process expanded="true" height="512" width="770"> <operator activated="true" class="naive_bayes" compatibility="5.2.006" expanded="true" height="76" name="Naive Bayes" width="90" x="313" y="30"/> <connect from_port="training set" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> </process> </operator> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="461" y="30"> <list key="application_parameters"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Polynominal by Binominal Classification" to_port="training set"/> <connect from_op="Polynominal by Binominal Classification" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Polynominal by Binominal Classification" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 2"/> <connect from_op="Apply Model" from_port="model" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
