I try to load a Naive Bayes Model from a .mod-File with ModelLoader, and it returns
Cannot read from XML stream, wrong format: com.rapidminer.operator.learner.bayes.DistributionModel.
Exception: com.rapidminer.operator.UserError
Message: Could not read file 'C:\....\bayes-model-14_1.mod': Cannot read from XML stream, wrong format: com.rapidminer.operator.learner.bayes.DistributionModel.
Stack trace:
com.rapidminer.operator.io.ModelLoader.read(ModelLoader.java:91)
com.rapidminer.operator.io.ModelLoader.read(ModelLoader.java:53)
com.rapidminer.operator.io.AbstractReader.apply(AbstractReader.java:52)
com.rapidminer.operator.Operator.apply(Operator.java:671)
com.rapidminer.operator.OperatorChain.apply(OperatorChain.java:424)
com.rapidminer.Process.run(Process.java:735)
com.rapidminer.Process.run(Process.java:704)
com.rapidminer.Process.run(Process.java:694)
com.rapidminer.gui.ProcessThread.run(ProcessThread.java:59)
Cause
Exception: java.io.StreamCorruptedException
Message: invalid stream header: 1F8B0800
Stack trace:
java.io.ObjectInputStream.readStreamHeader(ObjectInputStream.java:783)
java.io.ObjectInputStream.<init>(ObjectInputStream.java:280)
com.rapidminer.operator.io.ModelLoader.read(ModelLoader.java:70)
Any Ideas on how to load the model?
Thanks
Peter
