<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="polynomial classification"/> </operator> <operator name="OperatorSelector" class="OperatorSelector" expanded="yes"> <operator name="JMySVMLearner" class="JMySVMLearner"> <parameter key="keep_example_set" value="true"/> <parameter key="calculate_weights" value="true"/> </operator> <operator name="LibSVMLearner" class="LibSVMLearner"> <parameter key="keep_example_set" value="true"/> <parameter key="kernel_type" value="linear"/> <list key="class_weights"> </list> </operator> </operator></operator>
