<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="gaussian mixture clusters"/> </operator> <operator name="KMeans" class="KMeans"> <parameter key="k" value="3"/> </operator> <operator name="ChangeAttributeRole" class="ChangeAttributeRole"> <parameter key="name" value="cluster"/> </operator> <operator name="Aggregation" class="Aggregation"> <list key="aggregation_attributes"> <parameter key="att1" value="standard_deviation"/> <parameter key="att2" value="standard_deviation"/> <parameter key="att3" value="standard_deviation"/> <parameter key="att4" value="standard_deviation"/> <parameter key="att5" value="standard_deviation"/> </list> <parameter key="group_by_attributes" value="cluster"/> </operator></operator>
