<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="sum classification"/> </operator> <operator name="ParameterIteration" class="ParameterIteration" expanded="yes"> <list key="parameters"> <parameter key="OperatorSelector.select_which" value="[1.0;3.0;2;linear]"/> </list> <parameter key="keep_output" value="true"/> <operator name="XValidation" class="XValidation" expanded="yes"> <operator name="OperatorSelector" class="OperatorSelector" expanded="yes"> <parameter key="select_which" value="3"/> <operator name="DecisionTree" class="DecisionTree"> </operator> <operator name="LinearRegression" class="LinearRegression"> </operator> <operator name="JMySVMLearner" class="JMySVMLearner"> </operator> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="Performance" class="Performance"> </operator> </operator> </operator> </operator></operator>
