trying to perform an evolutionary parameter optimization on the
Weka-RandomForest learner
<operator name="ExampleSource" class="ExampleSource">
<parameter key="attributes" value="../data/polynomial.aml"/>
<operator name="ParameterOptimization" class="EvolutionaryParameterOptimization" expanded="yes">
<list key="parameters">
<parameter key="W-RandomForest.I" value="[1.0;100.0]"/>
<parameter key="W-RandomForest.K" value="[1.0;14.0]"/>
</list>
<parameter key="max_generations" value="10"/>
<parameter key="tournament_fraction" value="0.75"/>
<parameter key="crossover_prob" value="1.0"/>
<operator name="IteratingPerformanceAverage" class="IteratingPerformanceAverage" expanded="yes">
<parameter key="iterations" value="3"/>
<operator name="Validation" class="XValidation" expanded="yes">
<parameter key="number_of_validations" value="2"/>
<parameter key="sampling_type" value="shuffled sampling"/>
<operator name="W-RandomForest" class="W-RandomForest">
<parameter key="I" value="62.714679449413616"/>
<parameter key="K" value="12.223632520022772"/>
<operator name="ApplierChain" class="OperatorChain" expanded="yes">
<operator name="Test" class="ModelApplier">
<list key="application_parameters">
</list>
<operator name="Performance" class="Performance">
produces warnings of that type:
P Jul 9, 2009 6:22:51 PM: [Warning] ParameterOptimization: Cannot evaluate performance for current parameter combination: Cannot instantiate 'weka.classifiers.trees.RandomForest': java.lang.NumberFormatException: For input string: "56.645"
Does this mean that this Weka learner has some problems with arbitrary parameter values
and cannot be used for an evolutionary parameter optimization?
Paul
