<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="one variable non linear"/> <parameter key="number_of_attributes" value="1"/> </operator> <operator name="AGA" class="AGA" expanded="yes"> <parameter key="use_plus" value="false"/> <parameter key="reciprocal_value" value="false"/> <operator name="XValidation" class="XValidation" expanded="yes"> <parameter key="sampling_type" value="shuffled sampling"/> <operator name="LinearRegression" class="LinearRegression"> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="Performance" class="Performance"> </operator> </operator> </operator> </operator> <operator name="Construction2Names" class="Construction2Names"> </operator></operator>
