ClusterDensityEvaluator
Shubha
Shubha New Altair Community Member
I was working with the operator, "ClusterDensityEvaluator", with the below code.
    <operator name="ExampleSetGenerator" class="ExampleSetGenerator">
        <parameter key="target_function" value="sum classification"/>
        <parameter key="number_examples" value="200"/>
        <parameter key="number_of_attributes" value="2"/>
    <operator name="KMeans" class="KMeans">
    <operator name="ClusterDensityEvaluator" class="ClusterDensityEvaluator" breakpoints="before">
But the "ClusterDensityEvaluator" operator needs the SimilarityMeasure operator also to make it work. What 'SimilarityMeasure' is this? I meant the similarity measure from what to what?
Thanks for your help,
Shubha
Welcome!
  • land
    land New Altair Community Member
    this SimiliarityMeasure contains informations about the distance between each two examples. The below code will provide a SimiliarityMeasure
        <operator name="ExampleSet2Similarity" class="ExampleSet2Similarity">
        <operator name="ClusterDensityEvaluator" class="ClusterDensityEvaluator">
    Greetings,
      Sebastian
  • Shubha
    Thank you very much.
  • Shubha
    ..And can i get to know, how are the densities calculated based on these distances and the model? I meant to say, dod RM used any paper to perform this?
    Thanks,
    Shubha
  • land
    HI Shubba,
    yes of course it is based on some scientific research paper, but unfortunantely I don't know which one.
    Greetings,
      Sebastian
Welcome!
Welcome!
