Count a specific number in a set of attributes
Shubha
Shubha New Altair Community Member
I have a set of attributes and I need to create a new attribute which counts the number of zeros appearing in all the rows over the set of attributes.
I tried some like the below.
   <operator name="ExampleSetGenerator" class="ExampleSetGenerator">
       <parameter key="target_function" value="random"/>
       <parameter key="number_examples" value="10"/>
   <operator name="Real2Integer" class="Real2Integer">
       <parameter key="round" value="true"/>
   <operator name="AttributeAggregation" class="AttributeAggregation" breakpoints="before">
       <parameter key="attribute_name" value="new"/>
       <parameter key="aggregation_attributes" value="att.*"/>
       <parameter key="aggregation_function" value="count"/>
Though the AttrbuteAggregation operator has the COUNT function, it cannot count the occurance of a specific number over the set of attributes.
Thanks for your help,
Shubha
  • haddock
    haddock New Altair Community Member
    Hi Shubha,
    Nice problem for regex folk! Does this do what you want? Haven't checked it thoroughly, but you get the idea..
        <operator name="Set what you want to count" class="SingleMacroDefinition">
            <parameter key="macro" value="Look_for"/>
            <parameter key="value" value="-1"/>
            <parameter key="number_of_attributes" value="10"/>
        <operator name="IdTagging" class="IdTagging">
        <operator name="IOStorer" class="IOStorer">
            <parameter key="name" value="bla"/>
            <parameter key="io_object" value="ExampleSet"/>
            <parameter key="remove_from_process" value="false"/>
        <operator name="Numerical2Polynominal" class="Numerical2Polynominal">
        <operator name="Replace what you are counting with A" class="Replace">
            <parameter key="attributes" value=".*"/>
            <parameter key="replace_what" value="%{Look_for}"/>
            <parameter key="replace_by" value="A"/>
        <operator name="Get rid of all else" class="Replace">
            <parameter key="replace_what" value="A[0-9]+|-A|[-]*[0-9]+A|\-|[0-9]+"/>
        <operator name="Replace A with 1" class="Replace">
            <parameter key="replace_what" value="A"/>
            <parameter key="replace_by" value="1"/>
        <operator name="Add up the 1's" class="AttributeAggregation">
            <parameter key="attribute_name" value="Count of %{Look_for}"/>
        <operator name="FeatureNameFilter" class="FeatureNameFilter">
            <parameter key="skip_features_with_name" value="att.*"/>
        <operator name="IORetriever" class="IORetriever">
        <operator name="ExampleSetJoin" class="ExampleSetJoin">
            <parameter key="remove_double_attributes" value="false"/>
    Good weekend to all!
    PS Last edit I think covers most cases, also last version only worked on enterprise, as it used numerica2formattednominal, using numerica2polynominal seems to work OK.
  • Shubha
    That was interesting...  Thanks
    Shubha
