<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="sum classification"/> </operator> <operator name="IOMultiplier" class="IOMultiplier"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="ExampleFilter" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="label = positive"/> </operator> <operator name="IOStorer" class="IOStorer"> <parameter key="name" value="positiveSet"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="XValidation" class="XValidation" expanded="yes"> <operator name="OperatorChain (2)" class="OperatorChain" expanded="yes"> <operator name="IORetriever" class="IORetriever"> <parameter key="name" value="positiveSet"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="remove_from_store" value="false"/> </operator> <operator name="ExampleSetMerge" class="ExampleSetMerge"> </operator> <operator name="DecisionTree" class="DecisionTree"> </operator> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="Performance" class="Performance"> </operator> </operator> </operator></operator>
