I have a dataset where all missing values are represented by 999.
If I try to replace them with:
<operator name="FeatureIterator" class="FeatureIterator" expanded="yes">
<parameter key="work_on_input" value="false"/>
<operator name="Mapping" class="Mapping">
<parameter key="attributes" value="%{loop_feature}"/>
<list key="value_mappings">
</list>
<parameter key="replace_what" value="999"/>
<parameter key="replace_by" value="?"/>
then everything goes horribly wrong and when I try to send the data through a model it fails drastically in terms of the nominal variables.
If I set the filter to numeric only, then it changes the order of the variable list which messes up the model application in that there is an error:
May 28, 2009 10:12:33 AM: [Warning] W-J48: The order of attributes is not equal for the training and the application example set. This might lead to problems for some models.
A great helper on the list suggested that 999 should not input a replace_by value but then nothing appears to happen at all.
I have unticked work on input as it then seems to pass along the modified example set to the model applier further along. Should I be ticking work on input and placing the model applier differently?
So, what is the correct way to replace all values of 999 in a dataset with empty or blank values?
And how about just for numeric values?
Thanks!
