<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="random"/> </operator> <operator name="ExampleSetGenerator (2)" class="ExampleSetGenerator"> <parameter key="target_function" value="random"/> </operator> <operator name="ExampleSetGenerator (3)" class="ExampleSetGenerator"> <parameter key="target_function" value="random"/> </operator> <operator name="ExampleSetMerge" class="ExampleSetMerge"> </operator> <operator name="Sorting" class="Sorting"> <parameter key="attribute_name" value="att1"/> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator (3)" class="ExampleSetGenerator"> <parameter key="target_function" value="spiral cluster"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator name="KMedoids" class="KMedoids"> <parameter key="k" value="3"/> </operator> <operator name="Outlier Detection" class="OperatorChain" expanded="yes"> <operator name="ValueIterator" class="ValueIterator" expanded="yes"> <parameter key="attribute" value="cluster"/> <parameter key="iteration_macro" value="clus_num"/> <operator name="ExampleFilter" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="cluster=%{clus_num}"/> </operator> </operator> <operator name="ExampleSetMerge" class="ExampleSetMerge"> </operator> <operator name="Sorting (2)" class="Sorting"> <parameter key="attribute_name" value="id"/> </operator> </operator></operator>
