FeatureIterator won't work with AverageBuilder?
New Altair Community Member
Updated by Jocelyn
The MultilabelIterator example (in the Meta folder) has an AverageBuilder at the end. It collects the PerformanceVectors created during the crossvalidation runs and creates a final, overall performance metric.
But if I change the loop operator to a FeatureIterator, the AverageBuilder complains:
pre]AverageBuilder: Missing input: AverageVector[/pre]
To reproduce, start from the MultilabelIterator sample, add a FeatureIterator, move the inner operator of the MultilabelIterator into the FeatureIterator, add a ChangeAttributeRole into the FeatureIterator to change the labels. Finally, set the parameters. Here's the final version. Click "Tools | Validate" to see the error. You can run it with breakpoints to see it doing the right thing with the labels, but no performance output is created.
<operator name="MultipleLabelGenerator" class="MultipleLabelGenerator">
<operator name="NoiseGenerator" class="NoiseGenerator">
<list key="noise">
</list>
<operator name="FeatureIterator" class="FeatureIterator" expanded="yes">
<parameter key="filter" value="label.*"/>
<parameter key="work_on_special" value="true"/>
<operator name="ChangeAttributeRole" class="ChangeAttributeRole">
<parameter key="name" value="%{loop_feature}"/>
<operator name="XValidation" class="XValidation" expanded="yes">
<parameter key="sampling_type" value="shuffled sampling"/>
<operator name="DecisionTree" class="DecisionTree">
<parameter key="minimal_size_for_split" value="10"/>
<parameter key="minimal_leaf_size" value="5"/>
<operator name="OperatorChain" class="OperatorChain" expanded="yes">
<operator name="ModelApplier" class="ModelApplier">
<list key="application_parameters">
</list>
<operator name="Performance" class="Performance">
<operator name="AverageBuilder" class="AverageBuilder">
