By the way: NN is (in my opinion) the fastest way to check whether there are relations in data without applyinga too sophisticated learning workflow or the danger of overfitting data. Therefore I like to apply NN for a firstapproach :-) (answer for the other topic and only for my intentions on NN)
<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSource" class="ExampleSource"> <parameter key="attributes" value="C:\Dokumente und Einstellungen\Mierswa\Eigene Dateien\rm_workspace\sample\data\ripley-set.aml"/> </operator> <operator name="XValidation" class="XValidation" expanded="no"> <parameter key="keep_example_set" value="true"/> <parameter key="local_random_seed" value="100"/> <operator name="NeuralNetSimple" class="NeuralNetSimple"> <parameter key="default_hidden_layer_size" value="4"/> <parameter key="training_cycles" value="500"/> <parameter key="learning_rate" value="0.3"/> <parameter key="momentum" value="0.2"/> <parameter key="error_epsilon" value="0.0"/> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="Performance" class="Performance"> </operator> </operator> </operator> <operator name="XValidation (2)" class="XValidation" expanded="no"> <parameter key="local_random_seed" value="100"/> <operator name="W-MultilayerPerceptron" class="W-MultilayerPerceptron"> <parameter key="H" value="4"/> </operator> <operator name="OperatorChain (2)" class="OperatorChain" expanded="yes"> <operator name="ModelApplier (2)" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="Performance (2)" class="Performance"> </operator> </operator> </operator></operator>
NN is for me the safest way since I know, if I have 20, 40 or even 60 weights but 10000 or moredata lines with 10 or more attributes, it is quite difficult to overfit these data, isn't it?
