I'm trying to figure out how to make an H-plane cut in FEKO. Every cut I make results in an E field cut instead of an H field cut.
Hi @LearningFeko ,
I assume you refer to farfield requests? In this case only the E field (next to Gain, Directivity etc.) is available. You should choose nearfield requests instead. Then please make sure that electric and magnet field is calculated. Maybe you have changed this by mistake:
Best regards,Torben
