"Error getting IOContainer from Operator"
perhaps this is because i am not familiar with the api so well.
I want to catch the ClusterModel from a DBSCAN Clustering.
For this I have defined a ProcessFile int the RapidMiner GUI with an Arff-ExampleSource, an DBSCAN Operator and a ClusterModelWriter.
I want to use this Processfile in Java and get the ClusterModel without writing it to the filesystem.
I load just the processfile, and try to adapt the usage of an IOContainer from the tutorial. (RapidMiner is initialized)
at com.rapidminer.operator.Operator.stop(Operator.java:741)
at com.rapidminer.operator.Operator.checkForStop(Operator.java:735)
at com.rapidminer.operator.Operator.apply(Operator.java:615)
what have I forgotten or missed?
I appreciate your help
Thomas
but then i get an OperatorExceptionError:
Process clusterProcess = RapidMiner.readProcessFile(processFile);
Operator dbScanOperator = clusterProcess.getOperator("DBScanClustering");
IOContainer dbscIOContainer = dbScanOperator.apply(new IOContainer());
Thomas
1 - 2 of
21
this way you are just applying your operator, not the whole process. So the arff file is not loaded, and the clustering algorithm cannot work.
This way it should work: Greetings,
Sebastian
