...<operator name="Datenset Clustern" class="OperatorChain" expanded="yes"> <operator name="KMeans" class="KMeans"> </operator> <operator name="ClusterModel2ExampleSet" class="ClusterModel2ExampleSet"> </operator> <operator name="LinearRegression" class="LinearRegression"> <parameter key="keep_example_set" value="true"/> </operator> </operator>
<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="number_of_attributes" value="2"/> <parameter key="target_function" value="global and local models classification"/> </operator> <operator name="Datenset Clustern" class="OperatorChain" expanded="yes"> <operator name="KMeans" class="KMeans"> </operator> <operator name="ValueIterator" class="ValueIterator" expanded="yes"> <parameter key="attribute" value="cluster"/> <operator name="ExampleFilter" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="cluster = %{loop_value}"/> </operator> <operator name="LinearRegression" class="LinearRegression" breakpoints="after"> <parameter key="keep_example_set" value="true"/> </operator> <operator name="ModelWriter" class="ModelWriter"> <parameter key="model_file" value="C:\Dokumente und Einstellungen\sland\Eigene Dateien\yale\workspace\ClusteredLR - %{loop_value}.mod"/> </operator> </operator> </operator></operator>
