<operator name="Root" class="Process" expanded="yes"> <operator name="CSVExampleSource" class="CSVExampleSource"> <parameter key="filename" value="examples.csv"/> <parameter key="label_name" value="mylabel"/> </operator> <operator name="GridParameterOptimization" class="GridParameterOptimization" expanded="yes"> <list key="parameters"> <parameter key="RandomForest.number_of_trees" value="[1.0;100.0;10;logarithmic]"/> <parameter key="RandomForest.criterion" value="gain_ratio,information_gain,gini_index,accuracy"/> <parameter key="RandomForest.maximal_depth" value="[-1.0;100.0;10;logarithmic]"/> </list> <operator name="XValidation" class="XValidation" expanded="yes"> <parameter key="leave_one_out" value="true"/> <parameter key="sampling_type" value="shuffled sampling"/> <operator name="RandomForest" class="RandomForest"> <parameter key="criterion" value="gain_ratio"/> <parameter key="maximal_depth" value="-1"/> <parameter key="number_of_trees" value="5405"/> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="ClassificationPerformance" class="ClassificationPerformance"> <parameter key="absolute_error" value="true"/> <parameter key="accuracy" value="true"/> <list key="class_weights"> </list> <parameter key="classification_error" value="true"/> </operator> </operator> </operator> <operator name="ProcessLog" class="ProcessLog"> <parameter key="filename" value="/tmp/process.log"/> <list key="log"> <parameter key="iteration" value="operator.XValidation.value.iteration"/> <parameter key="time" value="operator.XValidation.value.time"/> <parameter key="deviation" value="operator.XValidation.value.deviation"/> <parameter key="variance" value="operator.XValidation.value.variance"/> <parameter key="accuracy" value="operator.XValidation.value.performance"/> <parameter key="classification_error" value="operator.XValidation.value.performance2"/> <parameter key="absolute_error" value="operator.XValidation.value.performance3"/> <parameter key="num_trees" value="operator.RandomForest.parameter.number_of_trees"/> <parameter key="criterion" value="operator.RandomForest.parameter.criterion"/> <parameter key="max_depth" value="operator.RandomForest.parameter.maximal_depth"/> </list> <parameter key="persistent" value="true"/> </operator> </operator> <operator name="PerformanceWriter" class="PerformanceWriter"> <parameter key="performance_file" value="/tmp/performance.per"/> </operator> <operator name="ParameterSetWriter" class="ParameterSetWriter"> <parameter key="parameter_file" value="/tmp/parameters.par"/> </operator></operator>
