Altair RISE
Nominate Yourself Now!
"Initialization failure in Linux Tomcat"
dongwookshin
I am trying to make Rapidminer work in Linux version of Tomcat. I managed to make it work in Windows Tomcat by using binary training file instead of text one. But in Linux when I started Tomcat, it crashed with the following error message.
G Dec 3, 2008 3:14:22 PM: Load JDBC drivers from classpath: false
G Dec 3, 2008 3:14:22 PM: Load plugins: false
G Dec 3, 2008 3:14:22 PM: Load plugins from '/usr/local/apache-tomcat-5.5.26/webapps/SemMedNHLBI/rapidminer/lib/plugins'
G Dec 3, 2008 3:14:22 PM: ----------------------------------------------------
G Dec 3, 2008 3:14:22 PM: Trying rcfile '/usr/local/apache-tomcat-5.5.26/webapps/SemMedNHLBI/rapidminer/etc/rapidminerrc'...skipped
G Dec 3, 2008 3:14:22 PM: Trying rcfile '/usr/local/apache-tomcat-5.5.26/webapps/SemMedNHLBI/rapidminer/etc/rapidminerrc.Linux'...skipped
G Dec 3, 2008 3:14:22 PM: Trying rcfile '/root/.rapidminer/4_3_0_rapidminerrc'...skipped
G Dec 3, 2008 3:14:22 PM: Trying rcfile '/root/.rapidminer/4_3_0_rapidminerrc.Linux'...skipped
G Dec 3, 2008 3:14:22 PM: Trying rcfile '/usr/local/apache-tomcat-5.5.26/logs/rapidminerrc'...skipped
G Dec 3, 2008 3:14:22 PM: Trying rcfile '/usr/local/apache-tomcat-5.5.26/logs/rapidminerrc.Linux'...skipped
G Dec 3, 2008 3:14:22 PM: Trying rapidminer.rcfile. Property not specified...skipped
G Dec 3, 2008 3:14:22 PM: Loading operators from 'operators.xml'.
X connection to localhost:10.0 broken (explicit kill or server shutdown).
I used both RapidMinerCommandLine and RapidMiner to see if command line version might not invoke X connection, but I got the same message. Do you know any way to get around for this? I'd like not to use any GUI related stuff. I looked the build.xml if I could rebild the rapidminer.jar, but had no idea so far.
Thanks,
Dongwook
Linux + variants
land
Hi Dongwook,
we will take a look, why this error appears. But so far we didn't have problems with the command line version of rapidMiner and the X Server. Perhabs the problem results from the tomcat, we didn't try to start rapidminer with tomcat, yet. Why do you try to start it with tomcat?
We will keep you informed.
Greetings,
Sebastian
homburg
Hi Dongwook.
Starting RapidMiner using the non-GUI script named "rapidminer" should not cause RapidMiner to acquire any X resources. Nevertheless the Tomcat server sometimes tries to connect to a certain display port as defined by the DISPLAY variable. There are usually two options to avoid this behaviour:
1. Try to call
unset DISPLAY
before you start the Tomcat server. This normally ensures that Tomcat runs in headless mode.
2. If, for some purposes, you need a DISPLAY variable set, try to run Tomcat/Java using the option
-Djava.awt.headless=true
in order to run server and java processes in headless mode.
Hope, this helps you to solve your problem.
Best regards,
Helge
dongwookshin
Helge:
It works by calling "unset DISPLAY" before invoking Linux Tomcat.
Thanks a lot,
Dongwook
