#!/bin/sh## set the path to your RapidMiner installation here or in an environment variable#RAPIDMINER_HOME=${HOME}RAPIDMINER_HOME=${HOME}/Programme/rapidminer-4.3JAVA_HOME=/usr/lib/jvm/java-6-sun/jre#JAVA_HOME=/usr/lib/jvm/java-1.5.0-sun/jre## set the maximum amount of memory Java uses here or in an environment variableMAX_JAVA_MEMORY=1024## set the path to the files with additional operators here or in an environment variable#RAPIDMINER_OPERATORS_ADDITIONAL=if [ -z "${RAPIDMINER_HOME}" ] ; then BIN_DIR=`dirname "$0"` RAPIDMINER_HOME=`dirname "${BIN_DIR}"` echo "RAPIDMINER_HOME is not set. Trying the directory '${RAPIDMINER_HOME}'..."fi if [ -z "${JAVA_HOME}" ] ; then echo "JAVA_HOME is not set. Edit $0 and/or your local startup files." exit 1else# _jfnd="`which java`"# if [ -x "${_jfnd}" ]; then# JAVA="${_jfnd}"# elif [ -x "${JAVA_HOME}/bin/java" ]; then if [ -x "${JAVA_HOME}/bin/java" ]; then JAVA="${JAVA_HOME}/bin/java" else echo 'could not found the `java? executable in default path or ${JAVA_HOME}/bin/java.' echo "Edit $0 and/or your local startup files." exit 1 fi unset _jfndfiif [ -z "${MAX_JAVA_MEMORY}" ] ; then MAX_JAVA_MEMORY=512 echo "No maximum Java memory defined, using 512 Mb..."fi...snip
