"Parameter macro process_path"
I can´t get the path of a process with the %{process_path}.
If I modify the 01_DecisionTree.xml with a reference in the log file I get an error
Cannot create log file: java.io.FileNotFoundException: C:\rmws\Sample\02_Learner\01_DecisionTree.xml\kk.log
The name and extension of the experiment is included. The same is obtained using process_name macro.
Can be used the macros in the root node?
Is there any other macro for the path?
Thanks in advance.
F.J. Cuberos
Thanks in advance.
F.J. Cuberos
<description text="#ylt#table#ygt##ylt#tr#ygt##ylt#td#ygt##ylt#p#ygt#This experiment starts with loading the data.
RuleLearner.#ylt#/i#ygt##ylt#/td#ygt##ylt#/tr#ygt##ylt#/table#ygt##ylt#/li#ygt##ylt#/ul#ygt#"/>
<parameter key="logfile" value="%{process_path}\kk.log"/>
<parameter key="logverbosity" value="all"/>
<operator name="Input" class="ExampleSource">
<parameter key="attributes" value="../data/golf.aml"/>
<operator name="DecisionTree" class="DecisionTree">
1 - 9 of
91
I´d already took the two shorcuts you comment.
I don´t understand that the process_path return the path and the name of the process.
If the name is obtained with process_name and process_file is logical to think process_path (and 4.0 tutorial states "%{process_path} becomes the path of the process file.") only return the path, because in that case the path+name can be obtained with %{process_path}\%{process_file}.
Thanks again.
F.J. Cuberos
Thanks again.
F.J. Cuberos
Hello
Yes, there is some kind of redundancy. But if %{process_path} would behave as you wish it were completely redundant, since RapidMiner resolves the path of the process-file automatically. I guess that the three different kinds of process-macros
beside: I do not know any usecase for %{process path} for its current or your desired behaviour.
greetings,
Steffen
are part of RapidMiner due to historical reasons...
%{process name} becomes the name of the process file (without path and extension).
%{process file} becomes the name of the process file (with extension).
%{process path} becomes the path of the process file.
greetings,
Steffen
HI Marius,
How can this \\LocalRepository\ repository path be converted to a valid system path in a WriteFile operator for example?
The two options to use relative paths (you suggested on October 07, 2008, 09:27:49 AM) do not write the file in the location of the process file but in my home directory. (Is this typical W7?)
Kind regards,
Bart
Kind regards,
Bart
I think that's not easily possible. But may I ask what you want to do? Maybe there is a better way of doing it than finding the process location.
Anyway, it is a bad idea to write anything manually into the directory containing the process, because it is located in the repository folder, which has a special format which should be maintained exclusively by RapidMiner (similar to a database or something).
Best,
Marius
Best,
Marius
Hi Markus,
I try to read a file settings to be used in macros in different projects. So i would like to put that file, say current.csv, in the folder within the local repository. The result is a file not found exception on \\LocalRepository\MyProjects\MySettings\current.csv
The only alternative is to define the full path to this file, but that is not the purpose of the default macros, right?
Kind regards,
Bart
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="721" width="1201">
<operator activated="true" class="read_csv" compatibility="5.2.008" expanded="true" height="60" name="Read CSV" width="90" x="112" y="30">
<parameter key="csv_file" value="%{process_path}/current.csv"/>
<list key="annotations"/>
<list key="data_set_meta_data_information"/>
<connect from_op="Read CSV" from_port="output" to_port="result 1"/>
</process>
</process>
Kind regards,
Bart
<context>
<input/>
<output/>
<macros/>
</context>
</process>
</process>
why not import the csv file into the repository and use Extract Macro to read the macro values from the example set? The attached process provides an example on how to do that.
Best, Marius
Best, Marius
<process version="5.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process">
<process expanded="true" height="562" width="718">
<operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve macros" width="90" x="112" y="30">
<parameter key="repository_entry" value="//LocalRepository/support/forum/macros"/>
<operator activated="true" class="extract_macro" compatibility="5.3.000" expanded="true" height="60" name="Extract Macro" width="90" x="246" y="30">
<parameter key="macro" value="macro1"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="attribute_name" value="macro_value"/>
<parameter key="example_index" value="1"/>
<list key="additional_macros"/>
<operator activated="true" class="extract_macro" compatibility="5.3.000" expanded="true" height="60" name="Extract Macro (2)" width="90" x="380" y="30">
<parameter key="macro" value="macro2"/>
<parameter key="example_index" value="2"/>
<connect from_op="Retrieve macros" from_port="output" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Extract Macro" from_port="example set" to_op="Extract Macro (2)" to_port="example set"/>
<connect from_op="Extract Macro (2)" from_port="example set" to_port="result 1"/>
</process>
</process>
The macro is working correctly:
%{process_path} = C:\rmws\Sample\02_Learner\01_DecisionTree.xml
The problem is that there is no folder named "01_DecisionTree.xml"
Here are a few hints regarding this problem:
- If you save your process before you run it and path parameters are specified without folders (e.g. like "kk.log") the files will automatically be saved to the folder where your process.xml is located
- If you want to save files to a subfolder of your process-folder, use something like "/testfolder/kk.log". Note that the mentioned subfolder has to be created MANUALLY
hope this was helpful,Steffen
