<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="number_examples" value="200"/> <parameter key="number_of_attributes" value="10"/> <parameter key="target_function" value="gaussian mixture clusters"/> </operator> <operator name="IdTagging" class="IdTagging"> </operator> <operator name="KMeans" class="KMeans"> <parameter key="k" value="5"/> </operator> <operator name="IOConsumer" class="IOConsumer"> <parameter key="io_object" value="ClusterModel"/> </operator> <operator name="ValueIterator" class="ValueIterator" expanded="yes"> <parameter key="attribute" value="cluster"/> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="AttributeConstruction" class="AttributeConstruction"> <list key="function_descriptions"> <parameter key="inner_label_%{loop_value}" value="if (cluster == "%{loop_value}", "%{loop_value}", "other")"/> </list> </operator> <operator name="ChangeAttributeRole" class="ChangeAttributeRole"> <parameter key="name" value="inner_label_%{loop_value}"/> <parameter key="target_role" value="label"/> </operator> <operator name="Relief" class="Relief"> </operator> <operator name="IOConsumer (2)" class="IOConsumer"> <parameter key="io_object" value="ExampleSet"/> </operator> </operator> </operator></operator>
